It's actually a resister pack.
On the early ones it's behind the passenger kick panel, below the glove box. I won't swear it's the same on your 97+, but that's where I'd look first. Robert
i dont know who you are answering... could it be the relay on mine or resistor since its now blowing at all... i have a xj
the resister is only used for the lower speeds if it doesnt work on high also which it straight thru 12 volts then you have a fuse or motor issue.
One of these days Zuk 2.0 |
#5 | |
Tony said his worked on high, but not the other settings. That'd be the resistor. Robert
Before I pulled it out to replace it I'd touch 12v to it by unplugging it & makign a jumper wire.
I believe your thread has officially been hyjacked by someone else... |
Oops, sorry... :o
Yea sorry about that. Game on.......
