hp 44 ?
i was wondering if anyone has ever used the dana 44 out of a 78 bronco with the cast radius mounts and radius arms on a xj. if so mabye someone could guide me in the right direction on how they did this. thanks
I welded upper and lower connection points for a 4 link set up around the stock radius mounts. It worked out well!
Guest
Posts: n/a
#4 | |
Your wifes pimp!
He did it the best way to use the axle end of the radius arm and use new tubes back to a better joint than the factory ford set up. And mount it all to a cross member. I did this to a guys jeep before and worked out really well.
ive seen a build up of a tj using radius arms on JA... can't find the thread right now... but it worked out well... binds a little bit, but almost any suspension does at some point.
Thanks for the help guys. I made these brackets to bolt to the frame, to use the radius arms but i think i am going to have to make the arms a little diffrent to work out well.
Your wifes pimp!
Those look good but I would try to get them mounted in one crossmember set up.
When I did it I made the them mount to a whole trans/tcase skid plate that tide the uni-body together.
