Old 01-27-2010, 04:12 PM   #1
8.25 vs. Dana44
Is a 8.25 as strong as a Dana 44?
Old 01-28-2010, 01:04 AM   #2
The 29 spline is pretty close.
The 27, not so much.
Chrysler 8.25 (1991-1996)
• 27 spline, 1.17" diameter shafts
• 8.25" ring gear
• 3.00" axle tube
Chrysler 8.25 (late 1996-2001)
• 29 spline, 1.21" diameter shafts
• 8.25" ring gear
• 3.00" axle tube
Dana 44 non c-clip
• 30 spline, 1.31" diameter shafts
• 8.5" ring gear
• 2.75" axle tube
Old 01-28-2010, 08:28 AM   #3
RuffedUpXJ
RuffedUpXJ's Avatar
Tony, what is in your XJ now? The 8.25 will bolt in when most Dana 44's won't plus it will cost a lot more. The 8.25 has a lot more aftermarket support now which is nice. I have a 29 spline 8.25.
Old 01-28-2010, 12:03 PM   #4
Looks like I have a 29 spline 8.25
Old 01-29-2010, 12:53 AM   #5
Originally Posted by RuffedUpXJ View Post
most Dana 44's won't...
Not sure what you mean by "most 44s" but I assumed he was talking about an XJ 44, which obviously would bolt in.
Pinion's a little longer, but that's all...
Old 01-29-2010, 09:04 AM   #6
RuffedUpXJ
RuffedUpXJ's Avatar
Yes thats what I meant Robert, considering $400 is about the going rate for the 87-88sih XJ 44 and you can get a 29 spline C8.25 for $50-&100. Also you could snag a 8.8 with Disc's and a mount kits for around the $400 range or cheaper if you are a shopper.
Old 01-29-2010, 12:59 PM   #7
All good advice.
I've even considered selling my locked and geared 44, doing up a 29spl, and pocketing the difference.
The 44s are over priced anymore. I sure wouldn't buy another.
Old 01-29-2010, 04:01 PM   #8
My first choice Dana 44...They hold their value. Have you called around ??With the the cash for clunkers program you may find one cheap ..
The 29 spline C8.25 will work fine too..
