D44 in a YJ?
A buddy of the owner brought his YJ project intot he shop to get a new clutch. He had me take a quick glance at it since I know more about the modified vehicles than he does, and I noticed that the front steering has issues that need addressed.
Someone has swapped a D44 with an air locker into this YJ, but the steering is rubbing a hole in the tie rod.... What are your suggestions? I suggested a SOA lift kit, but wasn't sure what to do with the steering after that. I assume with a larger lift he'd be running larger tires and would need a stronger steering setup. Take a look at the images below ![]() ![]() ![]() ![]() Last edited by jfiscus; 01-26-2010 at 09:54 AM. |
SUA... sounds like something that Paul would do...
![]() How about a non-drop pitman arm??
You beat me to the pitman arm idea. Does he want to change the ride height?
Ian 06 Toyota 4Runner |
change the shackles out to a boomerang style or longer possibly.
From the second picture it looks too me like there is a problem with the springs. The shackles are pushed way too far forward to be sitting in stock position.Look at it from the side. and maybe measure the springs and axle location on the springs ?????
Shawn |
Where would a TRE flip put you????
we were recommending he do an SOA lift, what do you suggest steering wise after that?
what else can I provide pics of? |
The Pirate
I agree with the above comment that something definitely looks different in regards to the front springs and shackle angle. Are they stock length springs? Are the mounts stock? I'm almost betting that the front axle was moved forward.
i know the object is to not shorten the wheelbase but is there enough room to redrill the fixed end mount and relocate the spring back an inch or so ? free fix with just a little time
One of these days Zuk 2.0 |
I would fix the coolant leak while it is in there too.
#12 |
VANILLA GORILLA
that minor jeep issue shouldnt affect how it pulls in 2 mall parking spots..... right?
hell tell him 2 buy a toyota
#13 |
you would NOT believe what he has into this thing...
Anyways, we pulled the trans & it's not stock either. From a visual inspection it looks like a GM 465, then adaptor, then an unknown tcase? Did YJs have that flange at the rear? We sent the pulled parts off to the parts house for them to match up; hopefully the new stuff works. ![]() Scott, if you might be interested in some work, give me a ring. 513-317-2314 - jason |
#14 |
I just thought about it. Check and see if you could do full crossover steering. The tie rod could go where it apparently originally went and the drag link could extend where the tie rod currently is. Check for clearances. Just an idea if they don't want to lift.
On the T-case, the possibility exists that it could be an oddball NP207 from and 87 wrangler. Never laid eyes on one, but they came in front of a Peugot trans that year so????
#15 | |
#16 |
Your wifes pimp!
the HD 242 from a HUMVEE has a fixed rear yoke does it have place for cooler lines?
