Poll: Dana 44 or 60?
I am trying to decide on which axle to use in a 2006 jeep rubicon unlimited. This jeep will see a decent amount of road use as well as serious rock crawling. Lift will be 5-6" and tires will be 37 to 39's. Should I keep the stock 44's and upgrade the shafts or throw in dana 60's? What do you think and why? Thanks in advance!
I vote for the 60. I know a bit about you and you will end up with the 39s. Also, the Rubicon 44 has 30 ends (Unit bearings, BJ, etc)
Plus, depending on the timing, I could use it in the front of my YJ ![]() ![]()
what are the 44's worth? rear needs to be checked out but so far I would say the passengers side axle shaft flange is bent.
The Pirate
I would not push over 37's with the stock 44's! Even then you may want better shafts and u-joints if your lookin at heavy weight 37's. 39's on 44's = broken junk every trip.
hellbilly fab
a 44 is a money pit.get a 60 . upgrade to 35 spline outers=manhood lol
The Pirate
Man, I can't find a Kingpin D60 driver drop that's worth the asking price, soo..... I got annother 14bolt and it's gonna become a front!!!!
SWEEEETTT!!!!! ![]() |
Your wifes pimp!
WTF do you think?:p
#12 |
Alright! Dana 44's it is then!
#14 |
It about killed me twice and took alot of life off the old dodge! Lots of stories for sure after being in or next to the truck for 35 hours running non stop. I will never do that again. Atleast not anytime soon.
#15 |
Ready to Wheel!!!!!!!
I have a set of matching rearends from a '99 F-350 if your interested. All wheel disc brakes, lockout hubs, 3:70 gears, brake lines all there and some steering components. Not a kngpin. Was going to build a rig before I bought mine last year.
1994 Dodge Ram 5.9L SWB 3/4 axles, 39.5 IROKS, HYDRO assist |
#16 |
The Pirate
Well I have (2) 14b rearends now, but how much???? is it a D60bj and what rear-end???? D70? Sterling?
#17 |
Front is balljoint. The rear I was told may be a corperate 10.25?? I will post them in the classifieds, i don't want to cludder this thread.
#18 |
Rear is likely a Sterling and the front is either a 50 or a 60. Srw got a 50 drw got a 60. Metric bolt pattern but stout axles. I have a set of u bolts, shocks and possibly some steering stuff from a drw F-350
#19 |
It is a single rear.
My plan was to do a Cherokee build with them at the time. If I decide to go through with it, I may contact you for some steering components if your selling.
