Old 03-30-2010, 08:36 PM   #1
My brakes suck
On my Yj I have 3/4 ton chevy calipers on the rear. I have a 67 vette master bolted to the firewall. Master cyl and front and rear calipers are brand new. Master was bench bled and I bled everything then gravity bled it all to make sure. I dont get a great pedal. Does anyone know of anything OEM I can bolt to my brake booster that will work well? It would be great to get power brakes back and have them work. Will a Rubicon master fit a Yj brake booster? I havent had good brakes for about 6 years so I am ready to try something different.
Old 03-30-2010, 08:53 PM   #2
I run 1 ton dodge ram master cyl. and booster with good luck. 95 to 99. Adjustable proportioning valve and rear disc brakes! Wonder if calipers are shot?
Old 03-30-2010, 08:53 PM   #3
i don't remember the exact year, but i believe it is a 86 ford van master cylinder will work. i have it bookmarked somewhere, and will try to find it. i need to do the same thing, i've never had a solid pedal either, it will lock up the tires, but it has always felt super soft.
greg
Old 03-30-2010, 10:08 PM   #4
To stiffen the pedal, you need larger bore on the cylinder. 3/4 to 7/8 or 7/8 to 1" makes a world of difference in pedal feel. Figure out what you have first, and go from there. A one ton master from a truck will stiffen you up, but might be too much. '
Look at the application and in your mind imagine how much fluid has to be pushed to fill the wheel cylinders / calipers on the system. find one that you think matches yours as close as possible.
Or bite the bullet and put a wilwood system in.
Old 03-30-2010, 10:14 PM   #5
This is why I called you earlier. I know the pumpkin had this same setup and I thought it worked great for you.
Old 03-30-2010, 10:58 PM   #6
Sorry I missed your call, I was eating dinner and forgot to call back. The pumpkin's brakes were ok, nothing stellar. I used the master for the car with 4 wheel disc MANUAL brakes. Makes a little difference. I'm not a fan of power brakes, so that would be the first thing I would lose. I imagine you have the cylinder for power brakes, as i recall you saying it was less than $20, and that is the power one. The manual one runs around $40-50. The manual has a larger bore, so it pushes more fluid. It doesn't matter how hard it pushes the fluid if there isn't enough there to fill the void it needs to.
Old 03-30-2010, 11:47 PM   #7
Waffle's Avatar
Images: 10
http://www.pirate4x4.com/tech/billavista/Brakes/
You might be better off looking at Billavista's brake bible. You need to start with matching the master to the front calipers and then go from there either up or down in size. There's a crazy amount of info in it. What's the bore size of your master? Front caliper piston surface area? blah, blah, blah.
If I remember right, vette masters are at best 1" bore. 1/2 ton and 3/4 ton calipers are the exact same. Only the rotor is different. I've got this setup front and back running a 1-1/8" master with 40's and love it. This was after ditching the 1".
don't go too large though. Larger=more volume and less pressure. (Hard thigh burning pedal but not enough pressure to stop)
Old 03-31-2010, 12:48 AM   #8
No I have the manual master cyl. Same way they are ok but not as good as I think they should be. I drove Steves jeep once and his brakes were great. He had the same setup I think.
Stickman how is yours set up? What application?
I am thinking the 1 ton dodge set up might be the way to go. OEM parts are nice. But as long as it works I dont care.
Old 03-31-2010, 05:38 AM   #9
I, as well as several others run an 1 1/4 bore master cylinder with chevy 1/2-3/4 ton single piston calipers front and rear with good results. The application is 68-74 ford f250 with drum brakes front and rear, or 75 e250 van. It is a direct bolt on to ford or jeep boosters and has an 1/8" port and a 1/4" port.
Old 03-31-2010, 08:11 PM   #10
Waffle's Avatar
Images: 10
OK, it's a yota. Dodge D60 front with 1/2 ton chevy calipers. Rear 14 bolt FF with 3/4 ton disc. Using an 85 Chevy K5 blazer master at 1-1/8 bore. I searched long and hard on this one. If using 1 ton front brakes even a 1-1/4 is likely too small.
What is your front axle? Your current Master is a 1" so maybe a 1-1/8 would be the ticket. I'm guessing your pedal hits the floor. If so I'd look here first. They're cheap enough.....
Old 03-31-2010, 08:35 PM   #11
Front is a dana 44 and the rear is a 60 using 3/4 chevy calipers
Old 03-31-2010, 09:22 PM   #12
Waffle's Avatar
Images: 10
http://home.4x4wire.com/erik/4runner/brakes/
Just some more info regarding a yota with D44. Erik B is fairly well known in the yota world and knows alot. The info here can be useful regardless of make and model. Including 1 ton swaps.
