Old 04-05-2010, 08:37 PM   #1
What about these? http://www.ruffstuffspecialties.com/...-id-p-361.html
7/8" 39,000 static load.
Old 04-05-2010, 10:23 PM   #2
tinbeater
tinbeater's Avatar
Kinda of overkill aint it.
Old 04-06-2010, 09:35 AM   #3
I don't know. Is it? This is why I am asking before I by them. What would you recommend?
Old 04-06-2010, 09:55 AM   #4
I 2nd qa1 3/4 teflon 27000 rating.
Old 04-06-2010, 10:05 AM   #5
When a heim fails, it fails completely. You either lose a link or steering arm completely from the attachment point. If it's a link, your axle shifts and probably wastes a coilover or airshock.
When a JJ fails, it just gets sloppy and horribly loose. but you will still get off the trail and back to camp without wasting a $500 shock. And it's rebuildable with common tools and a large bolt. I carry the guts for one JJ with me and a rebuild tool, and I'm good to go.
That alone should help you make your decision. Everything breaks, it's a matter of damage control when it does happen.
Old 04-06-2010, 12:05 PM   #6
i been runnin qa1 heims for a couple years now with some hard beatin and never had a problem...i think its a wash...heims all the way...if your doin both ends thats like 700-800 in joints to save a $240 shock???? does not make sense to me...especially never having a problem with them...
Old 04-06-2010, 01:02 PM   #7
It was a 500.00 shock. Coilovers run much higher than that. It may be a carWASH though.
