07-20-2010, 10:22 AM | #1 |
brake lines
i have a 98 tj in the shop right now and all the metal brake lines and the fuel return are shot (rust) just wondering if anyone has any suggestions on where to get a prebent possibly stainless kit at. i have dealt with classic tube on old cars but havent called anywhere yet. suggestions?
thanks scott
One of these days Zuk 2.0 |
07-20-2010, 11:24 AM | #2 |
Classic tube carries jeep kits as well... in fact, 4wd carries that same kit from classic tube...
http://www.4wd.com/productdetails.aspx?partID=8247 ah, and an omix/ada kit here as well.... http://www.4wd.com/productdetails.aspx?partID=58749
07-20-2010, 11:49 AM | #3 |
thank you. i was wondering about them just hadnt had the time to look. i have seen 3 98 tjs that the lines were junk on so i dont know if they(jeep)has learned anything from that
thanks again
07-20-2010, 01:17 PM | #4 |
The Pirate
The "green" hard brake line stuff at NAPA or any of the parts stores is hand bendable now days and is awsome stuff. You can get long enough sticks to handle any of the single line runs on a Jeep tub. We re-did the YJ and "moved" the lines to a better location than the factory run. Stuff also blows away the cost of the pre-bent lines as well.
Just my 2 cents worth. |
07-20-2010, 01:37 PM | #5 | |
07-20-2010, 02:12 PM | #6 |
agreed.
07-20-2010, 03:36 PM | #7 |
yeah in a situation where im doing something for a build or myself i would be looking toward bending and flaring my own because for some dumb reason i actually like doing that but since this is stock and a customer replacement job i will be looking toward the prebent kit but thanks for the input.
thanks scott
07-20-2010, 06:14 PM | #8 |
I used the pre bent brake lines from 4wdh when I put the new frame under my CJ 10 years ago.
07-20-2010, 09:22 PM | #9 |
Gearhead
Also check Inline Tube. They are in the same Michigan area as Classic and offer a lot of the same stuff (SS and Otherwise.) Both are old school good.
07-20-2010, 10:27 PM | #10 |
what a rust bucket....at least when it totally rusts away you can buy a gently used 6 inch long arm kit for you jeep
07-21-2010, 12:57 AM | #11 |
That's what I used to mate my 96 master with my 89 prop valve.
It did bend okay, but I had a hell of a time flaring it. I ended up having to scrape off all the green coating to get a grip on it... Robert
07-21-2010, 11:38 AM | #12 | |
thanks scott
07-21-2010, 10:22 PM | #13 |
They are horrible about calling back. I tried many times and left many messages and never heard back.
07-23-2010, 02:46 PM | #14 |
called back to classic tube since it seems all the venders get there lines from them anyway and talked to tim who said that they had one guy retire and one on vacation and that he was the only one there at the moment so long story short the lines are ordered and i will let you know how they look and work
thanks for the input thanks scott
