09-07-2010, 01:05 AM | #1 |
The best damn Engineer!!!
258 Rear Main Seal Replacement
I am attempting to replace my rear main seal on my 258. It is a 2 piece design and the upper half is in the block. Any ideas on how to remove the upper half of the seal from the block?
I am contemplating just replacing the lower half and leaving the upper alone for now. Any ideas would be greatly appreciated. Thanks, Frank |
09-07-2010, 07:02 AM | #3 |
Do I need to loosen all of the bearing caps? I have tried pushing on it but am a little concerned to push too hard in fear of scratching or marring the bearing surface. Is it okay to spray some penetrating oil on it?
09-07-2010, 09:37 AM | #4 |
I would NOT loosen bearing caps, I can't see more lubrication being bad.
Probably just stuck... you'll get it.
09-07-2010, 11:48 PM | #6 |
Got it out finally. Took a little penetrating oil and patience but its out now. Now I just to need to try and clean or get my hands on a new oil pump screen. Mine appears to be a little gunked up.
Thx for the info. I can always count on you guys to help. |
