Yota axles questions
Ok, I have maxed out my sami axles and I keep braking stuff...
specs: 5.38 gears lockers front and rear chromoly birfs calmini hd rear axles disco brakes in rear 4.1 tcase gears on 9.50x16 ag tires. now looking around it seems that the 85 yota axles 4.10 are the ones to find and get for a new swap out. what is the most bang for my buck to upgrade on the yota axles to get something close to what i was running with the sami axles? 5.29 gears? chromoly axles and birfs? weld rear and detroit locker front? pro/cons ? trail gear lockout coversion? 6 shooters? oh yeah still running tracker p/s with mod pump and cooler. Any issues that some one can see that I will need to swap some thing out for the steering (full hydro but not in the budget yet...), braking,etc...
Diesel guy
wonder if you were thinking of selling the sami axles :confused:;)
2013 RZR S |
Im by no means a yota guru, but I had built toy axles in my rear engine moon buggy, and had a lockrite in front that caused me headaches, so I would steer clear and stick with the detroight idea..
Yea lockrites are junk. I got a yukon grisly and it works great. And for axels, longfields are the the best. I run 39.5 tires and Ibeat the hell out of it and NEVER broke a axel or had any problems out of locker.
Sorry to hear you guys have had bad luck with lockrites... I agree the suck in the front, but i have run them in the rear of every Landcruiser i have ever had... The longfeilds are about the only thing i would put up front for an axle upgade, the warranty is the best you will find...
If you want to find more info on the Yota stuff look on IH8Dmud.com ... Here is a link to the Yota mini truck section http://forum.ih8mud.com/79-95-toyota-truck-tech/... ![]()
Longfields are the only axle to run. I run 38 sx's and never had any problems. I'm not easy on them either.
Willys buggy 4.3, 350 trans, toy axles, linked suspension, air shocks |
#7 | |
That sold them for me... Now i just have to save the $ to get some... ![]() ![]()
I had a lock rite in the front of mine for years,had a hard time getting it ratchet. I did finally replace with air locker best choice I made.
The front 4.10 gears with your t-case will do you good.The start of upgrades you can do is dirty thirtys from trail gear, and up grade as you can afford. If you leave front end unlocked stocks hold up pretty good,but once you lock they don't hold up as well. I run all upgraded front end parts and spool in rear. Hope this will help. FYI had lock rite for 6 years. |
#9 | |
#10 | |
hellbilly fab
i have had both dirty 30s and longfields. longfields are the way to go.lockrites are ok i ran one in my front for 3 years. but detroit is the way to go if your running 36 or bigger tires.
5.29 gears?....I would. chromoly axles and birfs? Longfields. weld rear and detroit locker front? i wouldn't put a lockrite in it 6 shooters? Too much money.... c link http://www.pirate4x4.com/forum/showt...highlight=stud oh yeah still running tracker p/s with mod pump and cooler. Any issues that some one can see that I will need to swap some thing out for the steering (full hydro but not in the budget yet...), braking,etc... u would need to run histeer and maybe a toyota p/s pump
#14 | |
4.62 gears, locked front spool? welded rear, rear disco setup with anti wrap (tractor supply) bar. need one chromoly and hub ( locker bolts sheared off) maybe brake pads or calipers on front not sure I took this apart when i need parts for splattt..
#15 |
also are the stock yota's
27 spline or 30 spline, I did see the longfields- 645.00 vs the dirty 30 - 579.00 they both seem to be made from same material not much a price difference.. so most say go with the longfields!! are the creaper flanges a good upgrade? pros/cons? http://www.trail-gear.com/hubs-and-drive-flanges they seem like they would be..
#16 |
Phil I just bought 30 splines because of the halloween trip where I brkoe 2 stock inners, so my chromo 27 spline longs are for sale with good inner shafts, $200 for both. With the short tire you have you won't break an inner 27 spline
edit: the one weakness yota axles have is TECHNO music, its something about the crappy repetitive beat that causes them to fail... |
#17 | |
yeah right!
#18 |
The only part that is 30 spline on the longfields is the end of the shaft that is in the birfield. The end that splines into the spiders is still 27 spline.
#19 |
Totally unrelated question... In ur pics u used to have boggers, now ag tires.
ag tires workin better for ya?
#20 | |
Plus my little 1.3 engine really did not have the hp (56 stock) to clean the tires out well enough to make them work well.. So i traded them off for 9.50x16 ag tires. they have worked great but not well in rocks so much so might have to get another set of tsl for that, I have been braking everything in a maxed out sami axle. I have put all the extra goodies in the axles and keep braking them chromoly birfs, 5.38 r &p , lockers,calmini rear hd axles, disco brakes, diff covers, 4.1 t case, tracker p/s with cooler and mod pump. so the reason for getting the yota's now and have to beef them up to handle it all...
Thanks, 67fastback ------------- 84 Honda cr60r - for sale 87 Honda 200sx - for sale 67 Mustang fastback - under restoration MCA #63430 04 Silverado 2500 crew cab 87 sami - "SPLAT" 87 sami tin top - "Blue Fire" 88 sami - "Squirt" My New Video Channel -http://www.youtube.com/PhillbillyProduction My Video Channel - http://www.youtube.com/justworkn ![]() Last edited by 67fastback; 03-05-2011 at 11:31 PM. |
#21 |
oh i see... thanks..
#22 |
Don't know if that was a typo or what but a stock front yota inner shaft is 30 splines at the side gears and tapers down to 27 at the birf. A 30 spline Long or dirty30 is 30 splines on both ends. Stock 27 spline inners break where they taper down between the birf and the machined surface that the seal rides on. The 30s don't taped down at all, and they don't break there.
#23 | |
Diesel guy
2013 RZR S |
#24 | |
Yes it was a typo. I was trying to tell the difference between 27 and 30 spline longs. Man I messed that up. Thanks
#25 |
pm sent!
