Old 04-27-2011, 05:05 PM   #1
Throttle plate
So, i just bought a propane kit and looks like i need a holly throttle plate to complete it.... Anyone know of a good source, or is this just need to take apart a junk carberator?
Old 04-27-2011, 08:28 PM   #2
cheapthrills49
VANILLA GORILLA
cheapthrills49's Avatar
nash fuel.com......click on "conversions kits" at the bottom of the page and then "throttle boddies" on the left he's in nicholsville, ky and helpful as hell, unlike carey
http://store03.prostores.com/servlet...IES/Categories
i have used the holly 2-barrell x ca225 on 3 different intakes(toy22r,toy2f and gm iron duke) theres is enough stock around the butterflies to re-drill another patteren
Old 04-27-2011, 09:11 PM   #3
Yeah, just bought a kit through him today, said he sells plates but his cost is prohibitive.... So tryin to find a better source...think uglyoffroad here said he has one to sell me.....
Yeah, bill nash is very helpfull
Old 04-27-2011, 09:21 PM   #4
superjeep
Ive got a holly 4 barrel sitting in the garage. It is the ford model so there is no Holley markings just a motorcraft tag.
Shawn
Old 04-28-2011, 07:28 AM   #5
Nuts's Avatar
I used a throttlebody of a vortec motor
Old 04-28-2011, 01:37 PM   #6
speedway motors has a billet aluminum throttle plate for 153$ same one nash sells for 325! if u use one on holley carb u hav to seal off middle hole in plate
summit and jegs hav it to proform co. that makes fawker
Old 04-28-2011, 02:54 PM   #7
Ill look up speedway....thanx!
Dident fully understand ur last sentance .....
Old 04-28-2011, 03:07 PM   #8
I have a standard aftermarket Holley 600 4 barrel carb on my shelf. Would that work?
Old 04-28-2011, 05:08 PM   #9
lmao! proform is name of company that makes plate. i think plate needs be off at least a double pumper or 4150 type carb, if u do use plate off holley u have to fill a hole in middle of plate with sumthing
Old 05-06-2011, 11:33 AM   #10
Well an update...
got one from uglyoffroad....it has vacume secondaries.. Did a search on pbb, pretty much the general thought is to rig up the secondaries to the primaries via mechanical ,......dident see that anyone is running vacume type w propane...
And yeah, guess i use jb weld to fill that middle hole like t/z said, along with all the vacume secondary ports
Old 05-06-2011, 11:37 AM   #11
If i had to guess on how to link these, id say not to bring secondaries on till primaries are 75% open.
But thats me guessin, so if anyone has imput id sit quietly and listen. Thanx
Old 05-06-2011, 12:12 PM   #12
riegel
hellbilly fab
riegel's Avatar
bill nash is the best guy around.he went way out of his way for me.he is way to high on his carb plate though.
riegel is offline   Reply With Quote
Old 05-06-2011, 07:46 PM   #13
dude wants like 325 for same plate!!!
Old 05-23-2011, 05:05 PM   #14
Another update...
Several theories on linkin these, most feel link secondaries directly to prims w no delay.. threw my 75% out the window...
But talkin to bill nash again confirmed letting prims open before secondaries.. although he suggested closer to 30%.. just to make sure full throttle has all open, which they do, btw...
Hopin to cruis down trail on just primaries and Sippin fuel, savin gas for pullin jwend up those big hills.. although I may be well off track on how pane mixer operates...
Old 05-23-2011, 07:18 PM   #15
I would go for the partial pedal only on the primaries. I would think about somewhere in the 50/50 to 60/40 range for primary. I think that somewhere in this range would be more linear in its reaction. The mixer is a flow based device, more air draws more fuel.
Old 05-23-2011, 07:31 PM   #16
Propane mixers only supply the amount of fuel the engine requires... doesn't matter what you do with linkage or if you have two bigass OHG X450's.
All mixers use the same amount of fuel with the CFM going through the venturi .. excessive fuel consumption come from an engine capable of moving enough air to use all the mixer(s) can support.
My propane experiences are that you only notice when you run out of flow capability.. you can make two big mixers drink fuel like one little one if you consciously baby the go pedal.
I got this info from the chaindrive guys who knew how to make a pane rig work.. I'm also basing this post on the assumption that the mixers in question are in proper adjustment.
