07-25-2007, 09:50 AM | #1 |
rockwell rims
I have seen people use the hummer rims that I currently run for the rockwell axles 6 lug bolt pattern. Anybody have any suggestions or ideas on a custom rim for the 6 lug axle application? (needs to be double beadlocked) :confused:
07-25-2007, 11:02 AM | #2 |
Your wifes pimp!
Stazworks or usa6x6
07-25-2007, 07:17 PM | #3 |
get centers cut to your spec's
weld them in to the desired backspacing
08-02-2007, 03:49 PM | #5 |
Sergeant
carwash, who did you get your centers from?
08-04-2007, 11:37 PM | #7 |
Throttle Jockey
Wheels
Go for the bling with the wheels!!!
08-05-2007, 06:26 AM | #8 |
used to cut centers out for John at
Stazworks, seemed like he had a lot on his plate, but he treated me right
08-06-2007, 06:27 AM | #10 |
You didn't ask.
if you bought your's from John, I may have
08-07-2007, 01:03 AM | #11 |
nope, bought from copperhead fab, and they suck.
jeff is still working on mine, and honestly i feel really bad that he has spent so much time working on them to get them usable. wish i had thought to contact you first about them.
08-07-2007, 09:33 PM | #12 |
I plan on trying the centers from Great Lakes Offroad they look good and it sounds like some of the problems Carwash had with copperheads center have been dealth with already. I am going to pick mine up in person when I am to that point so I can make sure they are right.
08-08-2007, 07:28 PM | #13 |
if you are talking about the great lakes offroad in indiana by ft wayne, i haven't been impressed by him. his work is good, but his communication and timeliness has sucked.
butch has had his last couple of sets (not including the current ones, as school was out for the summer) cut at the local vocational school. they cut it for the cost of materials on their plasma table, or laser. they came out great. that also is where all of our weldon beadlocks came from. check around at the local schools, i bet one would gladly cut em for ya, just for experience in programming and cutting. not sure where butch's most recent ones were cut, nick had em cut somewhere, i don't even think butch knows where. greg greg
08-08-2007, 10:07 PM | #14 |
Scott,
The name plate on my Willys was cut by waterjet at Advaned Welding in Franklin, Ohio. 1-937-746-6800 ask for Tony. They are open 0700- 1500, M-F. If you are thinking of having centers cut, Tony should be able to do it. John
1950 CJ3A. Oddfire 225 V6, T-86 transmission, Dana 18 transfer case, 4 wheel disc brakes, locked front and rear. Manual saginaw steering. Warn winch, 9,000#. |
08-09-2007, 08:14 AM | #15 |
Excellent! Thanks alot for the info
