Diesel guy
D44s or yotas for a sami??
Its a never ending debate amoung sami guys but I want local guys opinions. Which is better? I would be looking to gear them and spool the rear, locker in the front and other supporting mods. I plan on runing 36s or 38s. I can get a set of 44s pretty easily, ive looked for yotas (not real real hard) but havent been able to locate a set. HELP! :(
2013 RZR S |
i wont get into a better or worse opinion either but i have run a front 44 and rear 9" for about 6 years now in my sammy. my 44 has chromo axles and air locker the 9" has chromo axles and a full spool. 4.56 gears and 39.5" tires. the only problem i have ever had was wiping out a front ujoint and knocking the ears off a stock shaft but it was more my fault than the axle(r/f was the only wheel on the ground at the time)
One of these days Zuk 2.0 |
Diesel guy
Would I have more money in the 44s compaired to the yotas?
Also is yours a waggy 44 with ford hubs or what? Do you have any pics of the steering set up?
2013 RZR S Last edited by hotrod; 07-19-2011 at 05:01 PM. |
im for yota for eaze of install and having cv axles. set of longs in them and 5.29s you can beat guts out them, dont think u can go wrong either way though
SMITH BUILT PERIOD |
I have a set of yota axles behind my shed if you decide to go that route. PM me if your interested.
#6 | |
yes mine is a waggy redrilled to fit 5x5.5 wheels. steering is just a peice of 7075 with heims at the stock location and i built a highsteer arm for the drag link to attach to while using an ifs yota box. as far as pics i would say there is some somewhere and if i come across one i will post it for you
Well at this rate i bought my yota axles and kept a list of expenses of what I bought for them.
so far i am over 2000 in them with all the added goodies I got and more to come... so they can be pricey but i want somethign that I can beat on and not worry about braking.. ![]()
Diesel guy
Ya I was doing some adding last night and came up with about 1600 for toys. :( guess ya gotta pay to play haha.
2013 RZR S |
Yotas with longfields are going to be stronger than 44s. And 44s get really pricey when you start doing shafts and good ujoints.
Do yotas. If and when u build ur axles and the ring and pinion become the weak link its easier to throw a new third in at camp.. plus the whole setup be stronger imo
#11 | |
longfeilds,lockers,detroit, flanges,r&p gears, 5th bolt or 6 shooters, marlin hi steer, steering box swap or go hydro ,yj's or 4 link, drive shafts, t case cross member cut out for clearance,brake lines, rear disco coversion,surb m/c swap. adds up quick! built proof ![]()
#12 | |
#13 | |
Diesel guy
ive found good deals on both which was the original problem. I think im going to go yoda because of the huge aftermarket support for swaping them into a sami.
2013 RZR S |
