"BUILDING" 60s
I'm sick of baby sitting toyota axles every time I go out so I'm finally stepping up to man axles but I've never messed with them and don't really know where to start. I'd like to get a 60/14bolt set with 4;56s but the set on here is pretty far away and YJ60 hasn't called me back yet
35 spline chromoly outers with at least spicer joints at a minimum with those tires or you will be snapping shafts like tooth picks. Some sort of gussets on the knuckles to keep from ripping the steering arms off with hydro and a truss to keep from bending it. That's basically all my old jeep had done and I never had a problem with it, he'll that axle was in butchs red ch for 4 years before I got it (although I put the 35 spline stuff in it) biggest thing for you will be shafts.
Same advice as above for the front. Some sort of 35-spline stubs, at least Spicer joints, and make sure it has non-necked inner shafts at the minimum. On my Chevy version I have 35-spline Yukon stubs, Spicers, and new Spicer inners (bought years ago before any reasonably priced chromo's), with drive flanges. Also run a Lock-right with stock 4.10 gears. Never had a problem in the current condition after many years under a 6k truck with 40" Swampers, but I don't have a lot of power.
78Buford with his Ford version ran Spicer 35-spline shafts and joints with flanges for years. He did break a stub after several years of abuse under a 7k truck with 42's and a big-block, but the spindle bearing was also shot and had dug a groove in the shaft right where it broke. He didn't have as much luck with the Lock-right and now has a Detroit. Also broke one of the stock knuckles (this era Ford is known to have weaker knuckles) so he now has Cranes. With Yukon shafts and some sort of high-zoot u-joints, Detroit, and Crane knuckles he has beat on it for years without issues. Not sure if I would even bother with the rear 60. You can verify but the smaller 30-spline axle versions are pretty common and it takes a bunch of work to convert to 35-spline (but you might be lucky). I would recommend just holding out for a 14-bolt or D70. Neither is hard to find or expensive. |
i would hold out for 60/14b with gears already installd 456 or 488
SMITH BUILT PERIOD |
#5 | |
If you do plan on regearing keep in mind the carrier breaks. On the 14B try to stay with the 4.10 or higher gears as most of the aftermarket lower gears are designed as "thick" gears that use this carrier. If you have 4.56 gears and want lower you often need to get a new carrier. Also if you want a Detroit you want the open carrier as the Detroit installs like a Lock-right in these diffs and won't work with the factory posi. On the other hand, for standard rotation Dodge and GM D60's they don't make thick gears so anything 4.56 or lower requires a different carrier than the 4.10's..........of course if you are going Detroit, ARB, etc... it doesn't matter. |
Skip the dodge red headed stepchild axle and stick w a chevy if u are ps drop. Dodge short side is funky length, easier to fiind chevy spare shafts..
Weld rear carrier into " the orb of traction". X2 on payin a little extra for factory 4.56. --IF-- that ratio works for ya. If u changin it all out anyway then buy whats cheaper. If u love being narrow like a toy but strength of a 60, run uncut h1 wheels w 7" bs. Requires specific high steer arms but with 12.50 wide tsls I was79" wide outside to outside iirc on front, less in rear. Ill have a 4:56 front and rear up for sale here in a month. But they are dually. I'm gonna convert the front but rear is basically a 4:56 carrier with 300 lbs of useless attatched to it
my next rig will be on the trail before zuk 2.0 will ![]() Last edited by yellowjacket; 07-22-2011 at 03:12 PM. |
yeah that make sense, if i had to do over i would buy a set already built from someone parting out buggy, with everything done 5.38s and chromos and front locker. seems to b cheaper than giving 12 hundy for 60/14b then having to go through them and change everything. someones loss can b ur gain if u keep an eye in the 4sale section
So far i have worked out a FREE(buddy deal) king pin dodge 60 front and a $150 dana 70 rear with supposedly 4:88 or 5;13s.... For the price I'll probably get these;)
Wow! That's awesome. A Free 60.... AND a 70 in the rear. Hey u got any pics of ur rig not upside down? Or a build thread?
Its an old thread but except for the tires and gears its mostly the same.And there are pics of Facebook if you on there...
http://www.zukikrawlers.com/showthre...ght=buggy+redo |
RCV shafts in the front and aftermarket knuckles = done!
He's running stickies though, stickies have a bad habit of snapping factory splined outers, no matter the weight of a rig. Especially if he welds the front.
#14 | |
#15 |
u b ok wit 35 spline outers in 60, they will take a beating especially lite weight and low hp! alot of the "cheaper" Smith motorsports buggies are running spicer joints and spicer 35 spline outers with healthy sbc's and hold up well
#16 |
I broke two factory 30-spline stubs and found a 3rd one with a big twist in the splines, and that was with skinny 38's and 150 HP but under a 6k truck. I will say that who knows the previous life of these parts as the axle was pulled from a '77. I also previously broke a factory necked-down inner.
#17 |
Put "brute force" u joints in it.they're the best and Lifetime warranty too
#18 |
That's funny...........just talking to the other day with a friend and he made this joke. I know guys who believe this and whenever you recommend Spicer they pipe in with that comment.
#19 |
yeah i wouldnt even run 30 spline outers in the 60 if u wheelin it hard, go ahead and upgrade when u got it apart for locker. do people really use brute force joints wheelin? funny ****
#20 |
Puke force! Auto zone special!
