08-29-2007, 04:23 PM | #1 |
Jeepless
Grand Cherokee
What does it take to put 34" LTB or 35" Iroks under a Grand Cherokee. Is there enough body to trim. Just a new set of Coils.
I want to go wheeling and I found one fairly cheep that I can drive to the trail, wheel and drive home. IF 35's can't be done cheap what will fit? |
08-29-2007, 04:32 PM | #3 |
Your wifes pimp!
I would get some 2" spacer and do the 34" LTB's as the are tall but narrow so the will tuck in the wheel well alot easier. Would be a nice rig for the trail and flex well.
if i am not currently offending you, i will be shortly. |
08-29-2007, 04:37 PM | #4 |
Jeepless
That's what I was hoping to here. I;m not new to wheeling and I'm not to worried about flex because that skinny pedal can get you there with a little bit of body damage and some good skid plates. Haspin, 909, and the gorge don't need a lot of flex to have fun and stay on the main trails.
08-29-2007, 05:05 PM | #6 | |
Your wifes pimp!
Yeah me too!
08-29-2007, 05:10 PM | #7 |
08-29-2007, 09:08 PM | #9 |
some good reading...
http://www.ajeepthing.com/jeep-grand-cherokee-lift.html http://www.ajeepthing.com/jeep-grand-cherokee.html
08-29-2007, 10:52 PM | #10 |
08-30-2007, 01:04 AM | #11 |
Also check out this site : www.nagca.com , they have alot of info on the ZJ's
I would strongly suggest not going any bigger then 34's , and also build some rock rails before you take it any where . I was very impressed with mine and would still have today if it wasn't for the ecm issues it had from time to time. Mine had about 4-5 inches of lift on RE control arms welded in the rear with 33" tires . |
08-30-2007, 08:02 AM | #12 | |
08-31-2007, 02:47 PM | #13 |
Dont these GCs just have either a D35 or a aluminum D44?
I know people like to say they wont hold up to 33"+ tires, especially if they are welded/locked. |
08-31-2007, 04:38 PM | #14 |
Jeepless
With 33-34's and keeping it unlocked the aluminum dana44 will hold up. I wouldn't pick one up with a D35.
08-31-2007, 05:23 PM | #15 |
Your wifes pimp!
most are D35's Sarges had a D35 in it welded it did well and he just kept some spare shafts.
