Old 04-18-2012, 02:39 PM   #1
mossyoaktj
mossyoaktj's Avatar
upgrading tj trac bar
ive posted on this subject awhile back and now its back to the building steps. im looking at installing the clayton adjustable trac bar w drop bracket. frame side. but my question is about the drop pitman arm and axle side drop bracket that came with the lift.
i am running a 4in SA suspension which included a DPA and axles side drop bracket for the trac bar. so with installing the clayton kit, is the DPA needed and can i cut off the bracket on the axle and use the factory trac bar location.
i was looking throught the pictures of the one clayton has installed and it appears that they have the DPA but are using the factoring mounting hole on the axle side.
UNITED STATES MARINE
