setting backlash
ive been looking around for a good thread that goes in depth about setting backlash. i will be building my axles here soon this is my shy area. in case it matters i will be doin it on a HP30 and an 8.8
bryan
im good on the tolerance its more of the how to. ill be switching ring and pinion to run 4.88 well pretty much a complete rebuild. so a "how to set backlast correctly for dummies":confused: is what im lookig for.
Well, the placement of the shims differs with some axles. I have found that starting with the original shims gets you close. It can be a pain to get your correct backlash and a good tooth pattern. You'll need a dial indicator and a micrometer. Some of the shims are behind the side bearings, which need a puller or press to remove. I've read many how to articles online about it. I've done it about 7 times. I say read up a lot and dig in. Reading the tooth pattern tells you what it needs.
#5 | |
by the time all this goes together i will be out of the military (june this year) so might hav eto have a garage party with someone who can teach. id like to do it right the first time.
#6 | |
One of these days Zuk 2.0 |
Scott is right, there are a lot of variables. The hard part to me is changing the shims behind the pinion or carrier bearings. It is common to have to remove the bearings and change the shims multiple times. I usually make setup bearings out of the old ones. I grind them out a little so they come off easier. Research your specfic axle online and see how they do it. Way to much to list here.
#8 | ||
Student Driver
They are not to bad after you have done them. You also need some marker dye and a acid brush to check your pattern. The pattern can tell you allot about what needs changed. Backlash is just the distance the gears travel when you hold the pinion and move the ring gear. The pattern tells you where the gears meet each other. You get the backlash and pattern close and proper running bearing preload and nail it down.
#10 | |
#11 | |
The Pirate
![]() I have made set-up bearings for dana 30, dana 44, dana 60, and Ford 8.8 keep them in the garage for future axle projects. Good luck! ![]() |
#12 | |
#13 | |
corsets make it tighter
my 60 set-up set where made out of the old bearings too. Of course I'm also not setting up gears that will be used for a DD either. I think gears that don't see extended use at highway speeds have a whole lot more tollerance... One old timer told me "instead of getting a case spreader, shim it until the carrier is just snug to slide in by hand and then add another .004" before the final assembly"
Either way, a set of set-up bearings will make you a much less stressed out person when the time comes. Have fun. ![]() |
