If the craigslist guy that Hodges posted will rent you a deckover for $35 a day, that'd definitely be the way to go...
Doesn't look like he's showing one, but it'd be worth asking. Robert
I know i have seen an advertisement on CL for someone renting deck over trailers and i am pretty sure it is the guy i posted the link to, but not 100% sure... The was usually a pic of a deck over in the add... I'll look again this and see if i can find it for sure...
where is it? for the right money i could go get it.
A little off topic but is it the wrangler on rockwells on craigslist cuz if it is I need to see this thing.
BYAAH!!! |
i wouldnt b bit afraid haul it with half tires hanging off each side if you have it secured to trailer properly
SMITH BUILT PERIOD |
Like said above, there shouldn't be Any issue with some tire hanging off the side. With 8 inches still on the deck it would have to move a lot to be an issue, and if it does move that much you have bigger issues. I just used scrap 4x4s along the fenders to drive over.
it is not on craigslist, but a pic i can post.
lets c the pig!
