06-24-2012, 08:01 PM | #1 |
warn winch no work!!
i have a warn winch that i stuck in mud last fall. i have used it 3 months ago. reinstalled the winch now it doest not work . i checked the wires to make sure they were on right and they were. so i checked the solnoids power to both small screws but no power out to cables. so im guessing solnoids. ?? so i was cleaning some of the wires off and 1 broke off so i need solnoids ! were is the best place to buy them. thanks matt
06-24-2012, 08:14 PM | #2 |
I need to do this, too...
According to this: http://www.naxja.org/forum/showthread.php?t=1078763 The cheapest ones are here: http://www.dbelectrical.com/p-3579-4...6-smr6005.aspx $71 for the fourpack. If you find em cheaper, lemme know! Robert
06-24-2012, 08:33 PM | #3 |
I have been down this road before with the solenoids. MAKE SURE when you buy these that they are 100% duty cycle!! I bought some cheap replacements that were not 100% duty cycle and when I used the winch for the first time the solenoid shorted out and I could not shut the winch off. By the time I got it to shut off it had burnt the winch motor up and kinked the winch cable real bad. Sometimes a cheap price is not good.
06-25-2012, 10:56 AM | #5 | |
http://www.warnfactoryoutlet.com/sho...?edp_no=956552
Just another three linked stretched '95 YJ on 38s with a bunch of stuff scattered on the garage floor. |
06-25-2012, 12:26 PM | #7 |
Shoulda let tc drive... He wouldnt a needed a winch
S10 with a few air shocks.. |
06-25-2012, 12:31 PM | #8 |
06-25-2012, 02:43 PM | #9 |
sorry coach if i would had known i would have got them from you. ordered from dbelectric last nite. well see if they work may and try to pull winch apart this week. thanks matt
06-25-2012, 06:29 PM | #10 |
No prob. If those universal ones don't work out, I've got the Warn brand ones for ya. :)
06-27-2012, 09:14 PM | #11 |
well it worked for about 1 minute! then it is stuck on ! hooked up solnoids and it ran in and out several times out about 2 ft each time then back in , then it stuck on going in unhooked battery and reversed terminals to run it out! now what! i guess ill do some checking make sure i wired it right. then send them back i guess. anty suggestions? matt
06-28-2012, 11:54 AM | #12 |
If they worked correctly before for several cycles, then you've got them hooked up right. Probably just poor quality knock offs. Get the real Warn ones for a buck more. ;)
06-28-2012, 06:14 PM | #13 |
after tapping on them with a wrench they work for a few times then stick always going in. so ive got it narrowed down to 1 solnoid. i have 1 old one left that didnt break when removing. so ill switch them and hope it all works for the zukimelt! i hope we dont need a winch while there, but then if i dont need a winch we arnt having fun!!!!!! ill be calling coach!!!!! thanks guys !!! matt
06-28-2012, 07:22 PM | #14 | |
But, I thought the thing used the solenoids in pairs, wired in series as a failsafe? Ie: if either solenoid opened, the winch would stop, even if the other stuck. No? Could it be a problem with the controller? If you unplug it, does it continue to pull? Dunno... Robert
06-28-2012, 09:32 PM | #15 |
didnt try that but i will here in a few minutes.
