So I found out that RC offers a long arm upgrade with arms only for $900. Not a bad price to me, and it will remain a four link. Thoughts?........
I know, but I don't want to cut the brackets off for a triangulated 4 link. Its standard 4 link. Has to be better than a SA kit.......
#4 | |
The joints on the RC stuff is known to wear out fast and you are going to put it on a daily driver. The kit is bolt on and uses bad geometry on the rear links to make it easy to install. Lots of people have troubles with suspension unloading and bad handling characteristics. Why do you want a long arm? better flex? Cause you can get more than usable flex out of the factory short arm set up on a TJ. Here is mine with Currie arms and 12" travel shocks. If I went to long arms, I would just get hung up more on rocks and hate it. ![]() I am not sure if this is fully flexed out but its the only picture I have right now. |
How much lift do you have? Is that SA front and rear? I know my factory arms don't flex that much.... mainly I want to get my wheel base back. My back tires aren't even centered in the wheel wells
2.5" lift with flat fenders and currie arms. Using all 12" of the shocks. Front is all stock mounts except for shocks. Rear is factory lowers and triangulated uppers.
So could I lower a 4 inch lift to a 2 inch with the same arms? Until I can get adjustable arms ......
