02-01-2007, 11:10 PM | #1 |
gotta love middletucky
35's
how bad would 35's be on a four bananger trying to decide on what tire size I want 35's but think the four banger would crap out or the ax5 would
02-01-2007, 11:23 PM | #3 |
Your wifes pimp!
you will need 4.88's to make it worth it.
02-01-2007, 11:47 PM | #4 |
Your wifes pimp!
By the way I have some 35's here I need to move did you ever get your blower/heat working?
02-02-2007, 07:35 AM | #5 |
Jeepless
That ax5 will go long before the 4cyl. If you do the gears you'll be fine, stock is miserable. And you have to worry about the rear axle if it's a 35C.
02-02-2007, 09:29 PM | #6 |
what kind of 35's, yea i got the heat working it was a twenty dollar switch
02-02-2007, 09:48 PM | #7 |
with stock axles? (35 & 30)
02-02-2007, 10:12 PM | #8 |
With stock axles and 4.88's I would find a light weight 33 that is not too wide. If you really want 35's try the super swamper tsl bias ply tires in a narrow width or the irocs.
02-02-2007, 10:24 PM | #9 |
if i go 35's going to get a set of 44s, actually i need to do that any way so i'm in the market if anybody has some
02-02-2007, 10:40 PM | #10 |
I have a dana 44 with 4.56 ratio from a 1995 dodge ram. It comes with coil springs, steering linkage, steering box, steering pump, steering shaft, track bar, and 2 sets of extra inner axle shafts for the left and right side. 250.00
02-03-2007, 06:22 AM | #11 |
where are u located and my next day off isn't until tuesday would i be able to check them out then
02-03-2007, 09:14 AM | #12 |
I may be able to do that. Let me see how this weekend goes.
02-03-2007, 07:44 PM | #13 |
just let me know
02-03-2007, 11:54 PM | #14 |
anybody know where to find some spring perches for a tj
02-08-2007, 11:45 PM | #15 |
02-09-2007, 07:47 AM | #16 |
thanks sarge
02-09-2007, 08:51 AM | #18 | |
Your wifes pimp!
Ya! where's all your love Mike?
02-09-2007, 08:58 AM | #19 |
Hey dan, carwash has top notch quality spring perches made of the finest materials known to man and JET455 can weld em in better than anyone. And it could be done this weekend. Maybe
02-10-2007, 06:33 AM | #20 |
ooooppppps, I like your PG-13 Butt Hole comment !! it made me feel all warm and fuzzy
Hey Dan , This guy on our board ..... I think his name is CRANKWASHER or something like that sells parts from Ruff Stuff ..... you might want to give him a call |
02-10-2007, 07:40 AM | #21 |
all right I'll get a hold of this crank washer guy first, hey carwash if you could pm me your number
02-10-2007, 10:14 PM | #22 |
hehehehehehehehe
