Old 11-17-2012, 04:39 PM   #1
School me on battery isolators
Found one at Oreillys for $30 good for 95 amps. I guess my main question is when my main battery goes dead does it automatically switch over for starting?
Old 11-17-2012, 07:44 PM   #2
No an isolator doen't work that way, you would have to switch your battery leads around...
The way i understand it an isolator splits your charging lead and will not let the batteries back feed/drain the other battery if one goes dead... At least that what the set up in my 60 does... Also almost every isolator robs the charging wire of 1 amp...
Old 11-17-2012, 09:17 PM   #3
Not the answer I was hoping for. This changes my plans I think
Old 11-18-2012, 12:33 AM   #4
Sonnybob
No not automaticly i think
Sonnybob is offline   Reply With Quote
