Old 10-08-2007, 03:10 PM   #1
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
Suggestions on Drivetrain swap
Looking for suggestions on rebuild of my YJ. I picked up an HPD44 with Ox and D60 with Detroit from Hardluck friend for a good price. I was planning on regearing and running a flipped D300 on my YJ, but got to thinking today about not regearing and running an atlas. I will be running 37-38 tires AX-15 and 4.0
ORIGINAL PLAN
– Regear both axles to 5.13 and flip D300 - Gears and install kits ($550) ,D300 ($150), D300 Flip Kit ($550), Gear Installation ($200), Clocking ring ($100) = Total of $1550 for a Crawl ratio of 51:1
TODAYS CONTEMPLATIONS!
– Leave axles at 4.10 and buy atlas 3.8 or 4.3 - Cost $2000, Crawl of 60:1.
It would only cost me and addition $450 and would save a ton of time and hassle with re-gearing and flipping the D300.
I know overdrive would never ever be used but how underpowered would I be when not in low range? How bad do you think taking off from a stop would be? This is not a daily driver, but I do want it to be driveable on the road at 55-65 mph
Let me know what you think
Thanks
Josh
1994 YJ, 4.0, 5 speed.
Old 10-08-2007, 03:33 PM   #2
I know I can't answer your question posted above, but you're also gonna have to account for a few other expenses into either scenario. (driveshafts, axle perches/mounts, rims, etc) Are you planning a gas tank relocation & wheelbase stretch also? This kind of project can add up real quickly.
Old 10-08-2007, 03:54 PM   #3
Atlas is looking good. Are you running stock 30 and 35 axles now? If so you may want to go with stronger axles but if not run the atlas or the stak and have front and rear dig capability and sell the 300.
Old 10-08-2007, 03:56 PM   #4
JeepHD
JeepHD's Avatar
Yep, fully aware there are lots of other expenses. Thought I had it planned out when I got to thinking about transfer case/gearing options, and that's reason for the questions. I have a most of the parts purchased/and or priced. Overall, the project is going to cost upwards of 4-5k range, but I got about 3k out of the drivetrain and wheels and other parts I had. Not going to lengthen the wheelbase yet. Hopefully the 60 will custom clearance itself on the skid plate without too many problems.
Stak4x4 monstor boxes are also an option that I am looking into.
Thanks for the response
Old 10-08-2007, 03:58 PM   #5
JeepHD
JeepHD's Avatar
Was running 4.10s, 33s, D30 front Aussied, and an 8.8 rear. I already have the HPD44 and D60 that is going in, and is what initiated this rebuild!
Just started checking on the Stak boxes. I will be comparing them with the atlas.
Thanks for the input
Old 10-08-2007, 04:08 PM   #6
go with the Tcase gearing. not only will it be easier, but stronger as well (depending on if you upgrade gears on the 300 or not.)
go with the stak, but im biased, and havent even run mine yet.
Old 10-08-2007, 04:10 PM   #7
JeepHD
JeepHD's Avatar
Who did you purchase your stak thru? Or are you a vendor for them. Just looking for a good price.
Thanks
Old 10-08-2007, 04:14 PM   #8
I went through them directly for quick service. Carwash knows em pretty well too!
Old 10-09-2007, 08:18 AM   #9
JeepHD
JeepHD's Avatar
Well I am leaning toward a Stak or Atlas and leaving the axle gearing at 4.10 for now. I know it will be pretty weak on power in road gear for now but I can always change the axles down the road sometime. Should I go with the 3.8 or 4.3 gearing in the t-case?
Old 10-09-2007, 08:20 AM   #10
4.3 or the 3 speed stak and have multiple ranges! 3.73 or 4.10 ratio is said to be the strongest for a 44 or 60. Pinion still has some girth!
Old 10-09-2007, 08:22 AM   #11
JeepHD
JeepHD's Avatar
What did your 3-speed stak run you? I probably stick with the two speed due to cost
Old 10-09-2007, 08:28 AM   #12
I also would buy a stak or atlas for the money you would be spending...I would also regear to 4:56 OR 5:13
Old 10-09-2007, 08:31 AM   #13
JeepHD
JeepHD's Avatar
That's just the thing. Budget is not going to accomodate both the case and gearing. It's either gear the axles and flip the case, or leave the axles alone and get the low geared atlas or stak.
Thanks
Old 10-09-2007, 08:40 AM   #14
$2900 with options and shipping last year.
Old 10-09-2007, 08:43 AM   #15
JeepHD
JeepHD's Avatar
Thanks, I will be staying with the two speed.
Old 10-09-2007, 09:04 AM   #16
Then I would buy the atlas and regera later...Christmas present?????
Old 10-09-2007, 09:07 AM   #17
JeepHD
JeepHD's Avatar
Thanks, I will probably go with the T-case. Maybe gear swap next winter
Old 10-09-2007, 01:30 PM   #18
my stak was 3300, but i had some options added on, and that price included my adapter from TH400 to stak, as well as a new output shaft for my tranny.
Old 10-09-2007, 01:33 PM   #19
JeepHD
JeepHD's Avatar
Carwash,
Are you a vendor for them or can you get any discounts from them. I will be going with a 2 speed.
Thanks
Old 10-10-2007, 01:58 PM   #20
When is the delivery of the stak and what ratio did you go with?
Old 10-10-2007, 02:08 PM   #21
JeepHD
JeepHD's Avatar
Going with the 4.3:1. I have gotten and few prices on it and will order it soon. Looking at around $2330 shipped with the parking brake and VSS. Need to figure out what u-joints the pinion yoke uses so that I can match with the t-case and whether or not I will need CV on the rear.
From what I read on pirate, there will be a price increase in November.
Old 10-10-2007, 02:49 PM   #22
Check on stak4x4.com for info. They offer 1350 yokes standard and flanged and 1410 and others as an option. The parking brake option is awesome! You are going to love it.
Old 10-10-2007, 03:13 PM   #23
JeepHD
JeepHD's Avatar
I am guessing the 78-79 F250 axles use 1350 joints, if someone know for sure please post, othewise I need to try and get accurate measurements to find out. I am guessing that I will want a CV for the rear since I plan on tucking everything up in as high as possible and making a custom skid. Just need to decide on which yokes to use and then I can order.
Anyone around make good custom driveshafts at a reasonable price?
Old 10-10-2007, 03:28 PM   #24
Driveshafts at a reasonable price? No one around here that I know of. If you want to spend a fortune go to power clutch and drive. They make gold ones! :(
Old 10-11-2007, 02:18 AM   #25
LOL ... you got that one right
