- Administrator - |
Eps
I'm wanting to put power steering on my rzr. Any certain brand better that the others?
Here are some I found. Surly the factory unit is best, but also the most $$$. What about the others though? http://www.superatv.com/Polaris-RZR-...1083C1037.aspx http://www.wickedbilt.com/electra-st...steer-kit.html http://www.polaris.com/en-us/rzr-sid...er/pid-2878522 |
10
I installed super atv on mine. No complaints really. However it isn't speed sensitive like the factory power steering.
If you buy from super atv use this code at check out "RZRFORUMS". It will save you a bit of money. I think I ended up paying $585. |
- Administrator - |
Thanks, but I already bought it. Going to put it on today. I paid $520 for it. I can get used to the steering at higher speeds for saving $800. Speed sensitivity isn't worth $800 to me.
10
Exactly. That is why I went with super atv.
Are the kits you guy have plug and play?..I was under my dash today adding some rocker switches and noticed a couple capped off weatherpack type plugs in the harness. All I could think of was factory options my base XP doesn't have...power steering and winch ?
- Administrator - |
Those could be for the factory equipment. All I had to do was run the power wires to the battery and 1 small wire to the key on power under the dash around the 12v plugin. Same with the winch.
#8 | |
10
Those should be the keyed hot wires. I think there are two from my memory that are available. |
- Administrator - |
After using the Super ATV power steering for a while now, I can't complain. It seems to do the job. If anyone was questioning buying it, don't...
The one I bought. http://www.superatv.com/Polaris-RZR-...1083C1037.aspx |
