So the icing is actually called icenene i just found out.and itslike a hard foam when done. So i assume if u have 1 inchs worth put in then the batts that go over it have to be squished a bit..im not sure. If a 2x6 wall is 5.5, and the foam is 1, then you have 4.5 available..
So is the second type i mentioned worth the coin? It looks like regular insulation.blown in wet. And they kind of scrape it flush with the studs.
