- Moderator - |
![]() Your starting to spend more time and $$ in that thing than you are wheeling it. ![]() You are proof that those things are not cut out for what you wanna do with it. ![]()
#3 | |
![]() So how much have you spent this year on your rig? ![]() ![]() |
I got the front diff back together. Superatv has a lifetime warranty on their ring and pinion set and the sprag, so that cost me zero dollars. They also upgraded me to the 4140 steel sprag for free. I did have to buy a rebuild kit and a new armature plate. Between the 8 tab plate and the steel sprag, it should hold together better.
I believe the reason I broke the bearing carrier is I didn't know you were supposed to use Loctite 603 retaining compound on the bearing. That might have kept the c clip groove from breaking off. It will be on there from now on, so we will see if it happens again. Last edited by 93 Krawler; 07-19-2018 at 01:35 PM. |
- Moderator - |
[QUOTE=93 Krawler;89655] Most of our rigs weren't made for this abuse.
I'm ready to see progress and your new Rig on the trail that can handle abuse. ![]()
