Old 07-08-2018, 12:50 AM   #51
Superatv now has a steel sprag that they claim is indestructible. That sounds like a challenge to me
I believe 100% that you will be the person to prove them wrong and give them a bad name.
Old 07-09-2018, 11:51 PM   #52
Wow you Grenade’d that!
Old 07-17-2018, 05:16 PM   #53
Good thing i quit when i did...Click image for larger version
ID:	9928Click image for larger version
Old 07-18-2018, 10:48 PM   #54
Kevin it's time to park that $$ pit and get your new rig together.
Your starting to spend more time and $$ in that thing than you are wheeling it.
You are proof that those things are not cut out for what you wanna do with it.
Old 07-19-2018, 01:30 PM   #55
Says the guy with a jacked up ring and pinion... Hey, put your factory parts back on your yota and tell me how it does... Most of our rigs weren't made for this abuse.
So how much have you spent this year on your rig?
Old 07-19-2018, 01:49 PM   #56
I got the front diff back together. Superatv has a lifetime warranty on their ring and pinion set and the sprag, so that cost me zero dollars. They also upgraded me to the 4140 steel sprag for free. I did have to buy a rebuild kit and a new armature plate. Between the 8 tab plate and the steel sprag, it should hold together better.
I believe the reason I broke the bearing carrier is I didn't know you were supposed to use Loctite 603 retaining compound on the bearing. That might have kept the c clip groove from breaking off. It will be on there from now on, so we will see if it happens again.
Old 07-19-2018, 01:57 PM   #57
[QUOTE=93 Krawler;89655] Most of our rigs weren't made for this abuse.
I'm ready to see progress and your new Rig on the trail that can handle abuse.
Old 07-19-2018, 02:46 PM   #58
