Old 04-26-2010, 09:25 PM   #1
fordman00
fordman00's Avatar
not starting
I need your help guys. Went out to start my samurai today and she aint starting! Battery tested good. I dont know what else to do?? Any ideas! PLEASE HELP!!My truck broke today to! I'm in school and work.:confused: :confused:
Old 04-26-2010, 09:39 PM   #2
SixFtUnd
Danny Beach
SixFtUnd's Avatar
is it turning over trying to start ? did you check for spark at the plugs? it it getting fuel? More Info?
86 Ford Bronco
Old 04-26-2010, 09:47 PM   #3
fordman00
fordman00's Avatar
its not doing anything at all.no clicking or anything lights dont come on
Old 04-26-2010, 09:51 PM
fordman00
This message has been deleted by fordman00. Reason: double post
Old 04-26-2010, 09:51 PM   #4
SixFtUnd
Danny Beach
SixFtUnd's Avatar
did you check fuse's under the hood?
I had a car do that it was a fuse
dose the radio or anything inside the car work? thats what hapend to me wouldn't even try to start no lights but the radio and door locks worked
86 Ford Bronco
Old 04-26-2010, 09:52 PM   #5
fordman00
fordman00's Avatar
hmm.did not look but.i will tomorow
Old 04-26-2010, 09:54 PM   #6
SixFtUnd
Danny Beach
SixFtUnd's Avatar
good luck
86 Ford Bronco
Old 04-26-2010, 09:59 PM   #7
fordman00
fordman00's Avatar
haha.thanks this is a great start to the week.
Old 04-26-2010, 10:03 PM   #8
Waffle's Avatar
Images: 10
still could be any number of things. Ignition switch. Starter relay. Seized starter selenoid. Loose contacts or shorted/broken wire. Do you have a good repair manual for it?
Are you getting 12 volts at the selenoid? If not the problem is before it. Bypass everything and run a power wire straight from the battery + to the
12V + on the starter selenoid. Just give it a slight touch to a good clean contact. If it cranks it's something between the key and the selenoid. If nothing still try tapping on the selenoid and repeat step 1. If it cranks you'll need a new starter soon.Start there first.
Old 04-26-2010, 10:17 PM   #9
fordman00
fordman00's Avatar
haha.ok.sorry this is just amuzing because i just with through this sh!t with my truck tonight.its haveing the same problems.i will tommorow thanks
Old 04-26-2010, 10:30 PM   #10
fordman00
fordman00's Avatar
do you have any pictures of where the fuseable link is?
Old 04-27-2010, 07:15 AM   #11
SixFtUnd
Danny Beach
SixFtUnd's Avatar
it wasn't a fusable link on mine it was a regular fuse do you have a fuse box up under the hood?
I'll try and get a pic of one one one of my cars if I get the time today
but like stickman said it could be anything
86 Ford Bronco
Old 04-27-2010, 09:00 AM   #12
so, not turning over at all? Does the radio at least come on when you turn the key to start like usual?
sounds like the starter is bad, try hitting it with a hammer while trying to start it. that may get you home or to somewhere better to work on it.
Old 04-27-2010, 09:17 AM   #13
TomH
Gearhead
TomH's Avatar
Not enough info to help you. (Of course, if you swap enough parts, you'll get to it eventually.) Like others have suggested, use a test light and/or a multimeter to see whether you're getting power/ground to the switch, relay, starter, etc. Let us know whether the radio, horn, interior lights work etc.
Good luck.
Old 04-27-2010, 09:29 AM   #14
fordman00
fordman00's Avatar
haha.no radio.horn doesnt work even when i bought it.but the lights dont come on or anything.
Old 04-27-2010, 10:06 AM   #15
eighty3bronco
anywhere but there
eighty3bronco's Avatar
make sure all your cables are good and tight from your battery. if the battery is good and a cable has become disconnected then all thein things you are describing could and would happen
Old 04-27-2010, 10:29 AM   #16
I've had the same type of issue just because a battery cable was slightly loose and then corroded. Had to pull the cables off, clean everything, and put it back together. When I say loose, it's not like you could easily wiggle the cables on the battery but rather you could just barely rotate the clamp.
Old 04-27-2010, 10:31 AM   #17
there is a single wire conection next to the positive cable on the positive terminal at the battery (white plastic housing) that is your fusible link for the whole vehicle. if posibly a jumper box or anything got hooked up incorrectly it could blow that. it can be bypassed for test purposes.
Old 04-27-2010, 12:21 PM   #18
It is possible if you have a bad or corroded connection some where the rainy days and moisture can make it worse also... I would check the chassis grounds for corosion too...
good luck
Old 04-27-2010, 02:08 PM   #19
fordman00
fordman00's Avatar
got it it was the fusible link corroded and broke stripped the wire back and connected it back to the terminal and fired right up.
Old 04-27-2010, 02:09 PM   #20
fordman00
fordman00's Avatar
scott, did you ever figure out how much you want for them shifter seats?
Old 04-27-2010, 03:28 PM   #21
i see i still know a few things about the trouble spots.;)
shifter sheets
$12ea brass
$10ea poly
$6ea poly used
if that works let me know
thanks scott
Old 04-27-2010, 07:35 PM   #22
SixFtUnd
Danny Beach
SixFtUnd's Avatar
well I wasn't too far off fuse/fusible link haha
86 Ford Bronco
Old 04-28-2010, 07:50 PM   #23
fordman00
fordman00's Avatar
ok.scott.i will have to figure something out as i am away at school.
