- Administrator - |
95 S-10 Truggy Build
The base is a 95 S-10 ext cab. I will be using a lot of parts from my 93 full size PU.
This includes: Front axle: 79 Ford hi pinion D60, locked, 35 spline chromo in and out, drive flanges & 5:38 gears Rear axle: Ford 10.25, locked, stock shafts. Engine: 05 5.3, currently stock "for now" Trans: 4L60E T-case: NP 241 Suspension seats Fuel cell Rear drive shaft The plan is to 4 link front and rear with ORI 16" struts all the way around. Cut the frame off at the rear of the cab and tube it. Trying to stay around 117" wheel base. The front will be chopped off close to the water pump. Will relocate the radiator to the rear. Tube the front and mount the winch up front. Started on the interior today. It was nasty and there was a some alarm wiring mess that needed to come out. Someone put a push button to start it. I thought it was issues from the alarm, but it wasn't. After I got the mess out and hooked everything back up correctly, something is still wrong. When you turn the key on, it engages the starter. Sounds like the ignition switch. Gutted the interior and what a difference it made. The smell is mostly gone now. ![]() |
SeƱor Monkey
Looks like a good plan. What's your timeline for completion?
Ive had mixed opinions on the ORI's, none from personal experience of course. Why the decision to go the ORI route over a coil over?
Awesome build starting here Kevin. Let me know if i can ever lend a hand.
- Administrator - |
I like the rebound dampening the most. Not dealing with dialing in coils is a plus too. I have yet to see anyone that does what we do and not like them.
#7 | |
One specific reason i went with coil overs instead of the ORI's....In the event of a roll over, or any damage to the shock an ORI has the potential to prevent wheeling the rest of a trip (putting your rig out of commision). CO's will continue to maintain ride height using the springs where an ORI or air shock will compress when pressure is lost. Mark's roll on Grapevine as an example.
#8 | |
- Administrator - |
- Administrator - |
- Administrator - |
Been looking at heims, and link kits. Some kits had larger lowers than uppers, some were the same size. Are 1 1/4 heims with 2" 1/4 wall tubes good for my lowers? Same for the uppers, or smaller. Buy the brackets or make them? I have a plasma cutter...
I thought the shocks were expensive, the heims are ridiculous. About a grand for 16 1 1/4 heims. ![]() |
They call me......Scuba
1 1/4 is overkill for the lowers. granted, overkill is good, but 7/8" are fine. Most guys i know only run 7/8" without issue and is all i am running. Unless you beat it like a bouncer, you don't "need" 1 1/4 heims. especially on the uppers, they see far less stress than the lower do.
as for the tube, once again, overkill is not a bad thing and strength greatly depends on your over all length of the links themselves. a longer link will need a stronger material to better resist bending.
beat up rusted out k5 |
#12 | ||
I bet you could split the difference, though. 2 or 2.25 by 375 lowers on a 1.25 end, then smaller/lighter/cheaper uppers.
#13 | |
Actually I am on one tons and 38.5's currently, it will be placed everywhere Kevin plans on taking his in Harlan, the badlands etc.. I understand the compromise, but as i said, it is not just me. A few guys i know (not on here) run nothing more than good 7/8" heims on their full size rigs. If you think you need 1 1/4, then by all means get them but i am just saying they are most likely overkill. It is a lot of personal preference i guess. I'd have no concern with 2" 1/4 wall and 7/8" heims in that spot of your pic. Only time i have ever seen a 7/8" break is in a hard roll with lots of side load on them, but i've seen plenty of 1 1/4" break in that same situation as well.
#14 |
- Administrator - |
I was under my rig yesterday looking at everything I would have to transfer/redo on the s10 and decided it would better and quicker to just use the full size frame and put the s10 cab on it. My down time on the rig will probably be a little longer, but I think the overall time will be much quicker. Not having to take the drive train out will be a big help. I just have to decide when I want to stop wheelin the truck and tear it down. I still have the RZR to take on the trips.
I did some measuring and I like the numbers. ![]()
#15 |
Downtime will be longer, but overall build time should be shorter i would guess. seems like a pretty viable option.
#16 |
- Administrator - |
Been doing what I can till I rip the other one apart. Hit u pull for some parts. Replaced the ignition switch, and no more starter issues. Found a non a/c blower box to get rid of the huge a/c one. What a difference. Thanks Mark!! Had to replace most of the interior. Pulled the suspension seats out of rig to get them fitted in this one. I really like the space in the cab. I was expecting to feel cramped compared to the full size, but I wasn't at all. It is nice to be able to recline my seat without hitting the back window. Still looking for an auto console so the shifter will be between the seats. The stock 1500 4x4 shifter should work out in the s10 cab.
I decided to tear the rig apart after the Windrock trip in September. Hoping to have it done by the Harlan southern shine in May. That's about 9 months... ![]() |
#20 |
Gone, or just out of the garage?
Cut that frame in two, bolt a coupler to the back half, and sell your new "trailer" for half what you paid for the truck! ![]()
#21 |
- Administrator - |
#22 |
Where did you take it that gave $200? Most places I have heard only offer $50-100 right now for scrap vehicles.
#23 | |
- Administrator - |
Garden st on new haven rd. 110 a ton for unclean at 3120lbs. It was like $172 and I had a few radiators and some brass to go along with it. Together it was $196. |
