01-30-2017, 05:56 PM | #1 |
- Moderator - |
Driveshaft builder
Looking for a driveshaft builder or someone that can make one out of 2 I have that would be straight enough for trails. Looking for cheap! Not Tom Woods or Cincy driveline. I thought someone knew of a guy who had a lathe that could spin them to make sure they were straight and weld them up. No balancing needed for a trail rig.
Keep them on all 4's |
01-30-2017, 07:45 PM | #2 |
I've used B&T up in Milford. I remember that they were cheaper than Woods, but maybe not a lot.
Seemed like good work though.
01-30-2017, 09:43 PM | #3 |
No lathe needed. Cut the welds with a chop saw, cut to length, weld yoke back in. Use a striaght edge to get it striaght.
Sent from my SAMSUNG-SM-G891A using Tapatalk |
01-30-2017, 09:48 PM | #4 |
square tube.
01-31-2017, 01:11 PM | #5 |
If you have a dial indicator you can make them easily. Once it is cut to length and and the yoke is pressed back in (make sure you have the u-joints aligned with each other at the ends), bolt it back into your rig. Have someone slowly rotate the tires while you watch the dial indicator. Get it running as close to true as possible. I usually get them within .010" and they run good even on the street. Then weld it up making sure to make small welds alternating around the tube so it doesn't pull too far to one side. I keep checking it with the indicator and weld at any high spots to pull them back.
02-01-2017, 01:15 PM | #7 |
The first one I made that way I took up to Cincinnati Powertrain in Sharonville to have them balance it. They laughed when I told them how I made it and said they would "fix it" for me. When they checked it out, they couldn't believe how straight it was. They didn't even have to balance it.
02-01-2017, 04:54 PM | #8 |
never put an indicator on one ive done, just an eyeball, only the one that I made in the woods wobbled any. it wobbled alot
02-02-2017, 09:20 AM | #9 | |
- Moderator - |
