Old 11-17-2008, 05:06 PM   #26
sickws6
cut off & weld the shock mounts onto the 8.8 when you do the spring perches.
jeep only welded these on the outside of the mounts - making it easy to remove these off a junk axle.
definitely keep the disks for better stopping power, you may need to adapt the two lines from jeep metric to ford if they are standard, but that is cake.
gotcha, is there engough hydraulic pressure for the ford calipers?
sickws6 is offline   Reply With Quote
Old 11-17-2008, 05:16 PM   #27
Yes. You can easily carry around a D-35 all day long by yourself. A 8.8 takes 2 people to lift it. Its a no brainer. Trust the people who have delt with this. its well worth it.
Old 11-17-2008, 05:42 PM   #28
sickws6
Well It looks like I have made up my mind and it is better to do it right the first way instead of waisting money getting another d-35 I will now be looking for a 8.8 with 4.10's! Thanks guys for the input it really helps a lot.
Old 11-18-2008, 08:19 AM   #29
X2 on doing it right the first time.
