Old 04-29-2009, 11:58 AM   #26
Bear Chow
Bear Chow's Avatar
I would just weld a good nut to the end of each one of those lug nuts and prepare myself to spend money on new ones. (they do get pricey when you add them up) If you can't do that is the vehicle mobile? I'm sure a goodyear, tire discounter, or even walmart would be happy to exchange some dollars for some labor.
Old 04-29-2009, 04:36 PM   #27
bigbadxj
BIG DADDY
I may just do that! take it and say I can't get them off and not tell them that they are stripped, seized, and completely ****afied!
bigbadxj is offline   Reply With Quote
Old 04-29-2009, 04:58 PM   #28
Bear Chow
Bear Chow's Avatar
No matter what you bring them, they have seen worst.
Old 04-29-2009, 06:40 PM   #29
Drill it out ... carbide faced masonry bit if a regular cobalt/HSS twist drill has problems dealing with the stud material.
Step drill up to something close to the dia. of the stud ....then drive a hex bodied chisel into the hole ... put adjustable wrench on the hex body and work whats left of the nut/stud in various directions until metal fatigue becomes your friend...enjoy
Old 04-29-2009, 10:56 PM   #30
bigbadxj
BIG DADDY
Thanks for all the help guys and I'll let you know when and how I get them off!
Old 04-30-2009, 07:53 AM   #31
And don't forget the anti seize the next time around.
Old 04-30-2009, 07:43 PM   #32
8UP
Huh? Are we talkng about the factory nuts here? The ones with the crappy stamped cover on them? Hard to tell from your pics. If so split the cover off with a chisle, drive the smallest socket on the actual nut (usually metric) and turn 'em off. It's hard for me to believe you could drive a socket two sizes smaller than the nut if it's a solid nut.
Old 05-01-2009, 01:18 AM   #33
bigbadxj
BIG DADDY
Believe what you want but I did. Trust me No One wants these off more than I do! So I have no reason to lie. I tryed drilling into one and using a hex socket hammered it in there and snap one snap two snap three sockets your out! Then came the rain!
