Old 03-18-2012, 04:26 PM   #26
cmartin
cmartin's Avatar
Originally Posted by jlynch View Post
This works I have done 4 like this.
J bird knows. Mine was one of them. Hahaha
Old 03-18-2012, 04:42 PM   #27
tjrider
In the diagram it only has 1 relay? Is that right? Couldn't see it real good:confused:
Old 03-18-2012, 08:47 PM   #28
jlynch
You need 2 relays. One will be for the low side, which is a standard relay that you can get from advanced auto or auto zone. We got ours from an electronics store in Springboro. I can't remember the name of the place but they have a relay and a pigtail to plug into it. The second one is for the high side, which needs to be a high amp relay. We used the 75 amp bosch. If you need a hand let me know. You could bring your jeep over here or I could come to you. I live in Middletown.
Old 03-19-2012, 08:11 PM   #29
tjrider
What did you use for the temp control? Oreily sells the hayden ones
Old 03-20-2012, 06:50 AM   #30
jlynch
We did not use a temp control. I run mine on low all the time and switch it to high if the motor gets warm. Low keeps it cool most of the time. It should not be a big deal to hook up a temp control if you want one.
Old 03-20-2012, 09:48 AM   #31
kyrel69
The place is called Parts Express
Old 03-20-2012, 12:49 PM   #32
fmlewis
The best damn Engineer!!!
You can buy a thermostat control from just about any parts store. I found mine at Advance. You can wire it inline with your relay so you can either manually control the low speed or let it come on automatically. I leave it on auto. If your running low all the time you will drain your battery so keep an eye on it.
Old 03-20-2012, 04:38 PM   #33
tjrider
I definitely don't won't it running all the time. I just want it on a temp control without a switch. I'm not a huge fan of deep water anyways
Old 03-20-2012, 04:57 PM   #34
cmartin
cmartin's Avatar
Understand that especially if it is streetable. Ours are trail only rigs and crawling around in the woods in the summer the fan would be on all the time anyways. (Plus im to cheep to buy a sensor Hahahahahaha)
We are supposed to turn it off in deep mud holes but i never remember. You may want an off switch wired in somehow just in case you do end up somewhere and dont want it running
Old 05-11-2012, 05:17 PM   #35
tjrider
So I've been running this kit from Hollister road Co. For 3 weeks and its been great. Fan cycles on and off like factory. Very well built kit, only $94 too
Old 05-27-2012, 12:04 PM   #36
tjrider
Well...... everything works great when the fan motor is turning.... guess that's what you get from a junkyard sometimes. Gotta order a new motor and well be good to go
Old 05-27-2012, 02:29 PM   #37
Haddix505
Haddix505's Avatar
What year Tuarus is the good fans in?
Old 05-28-2012, 07:53 PM   #38
tjrider
95-96ish. I believe it was the3.8 motor. Make sure the fan has 3 wires coming out of the motor
Old 07-05-2012, 06:12 PM   #39
tjrider
It lives!!!!!!!! Had to wait a while for a new fan motor
Old 07-09-2012, 08:50 AM   #40
How thick is this fan? I would like to see if it will fit between my radiator and engine.
Old 07-09-2012, 12:36 PM   #41
tjrider
I can measure it tonight, but I'd say @ 3" with motor. Not positive
Old 07-09-2012, 09:49 PM   #42
tjrider
My tj only had @4" between the block and radiator. You can trim some of the shroud as ling as it still fits your radiator. They are pretty slim though
Old 07-09-2012, 11:09 PM   #43
I may go this route then instead of changing the oil in my fan clutch. What application did you end up sourcing from?
Old 07-10-2012, 07:13 AM   #44
tjrider
95 Taurus with the 3.8 motor. Single 3 wire fan
