Old 12-22-2012, 09:57 PM   #26
started the meat of the work today. Gonna be a Drivers Drop K5 now.
putting a 79 ford HP 60 under the front, using a later model GM drivers drop 241 in place of my current pass. drop 241. From what i have read, there should be no clearance issues from changing to drivers drop, so we are gonna find out.
That's the same setup I have under mine. I have a flat skid plate from rail to rail under the transfer case. Not sure how tall your frame rails are compared to mine. It makes for a nice flat underbody. The 700R4 and the 241 make for a good low crawl ratio for a stock setup. Mine crawls good with 5:38's. Hope to see you out wheelin soon.
Old 12-22-2012, 10:34 PM   #27
i have the SM465, so first is Really low already even with the stock 3.08s in the 10 bolts, but the tons have 4.10's in them. not idea for a 37-38" tire, but much better than the 3.08s for sure.
with my passenger drop case, i clocked it up already to give me a flat under side, gonna have to see where the driver drop case is gonna hang, but hopefully i can clock it up to give me a flat underside as well.
Old 12-23-2012, 08:26 AM   #28
Please get those cinder blocks out from under it!
LIKE IT OR LEAVE IT!!!
Old 12-23-2012, 12:00 PM   #29
or atleast turn them so they can bear weight
Old 12-23-2012, 02:10 PM   #30
frankensteinxj
frankensteinxj's Avatar
BYAAH!!!
Old 12-23-2012, 09:03 PM   #31
Noted on the blocks fella's.
Old 12-26-2012, 10:38 PM   #32
on its own weight. shocks, brake lines, transfer case and steering is all that is keeping me from driving it. that, and lack of decent tires. front swap went much smoother than the rear.
Old 02-03-2013, 08:16 PM   #33
a few more recent pics of it
bed sides will be going back on, something like this
its not done, but the main portion is. have more bracing to do still, adding a couple more frame tie in as well, as i don't like having the supports solely on my sliders.
Old 08-24-2013, 08:32 PM   #34
been a while, wheeled a few times, but is it still a work in progress but nearing completion all the time other than i keep adding stuff to the list of stuff i want to do to it.
Old 08-24-2013, 11:47 PM   #35
is it me or doe it seem that your cage needs some more bracking in the corners? looks like it would clasps in a roll...
Old 08-25-2013, 11:25 AM   #36
While i assure you it is not the best designed cage out there, i feel confident in its structural integrity to withstand a roll.
I do plan on adding more to it this winter. finishing out the front, as well as add some more bracing to it.
Old 05-05-2014, 09:19 PM   #37
been a bit of work since last time i updated this.
Bead locks, bumper, Anti wrap bar, and Custom exhaust from head to Tip
old headers did not like the HP ford axle up front
built some headers (no pics), but did something i had never seen done before, and built my own chambered mufflers.
baffles
and a sound clip.
https://www.youtube.com/watch?v=gF9POm_doqQ
bumper
and bead locks. went to the Badlands and had a big issue spinning the wheels inside the tires when under strain and thus far, the beadlocks seemed to have solved this issue.
