Old 06-16-2013, 05:59 PM   #51
cmartin
cmartin's Avatar
Looking Good! should be pretty stout but then mine are 1/4 wall dom and I managed to bend a lower rear last year.......
Wow thats what my lowers are is 2" .250 wall. Seems hard to believe that they would bend with how heavy they are
Old 06-16-2013, 06:08 PM   #52
cincygman
Well the Grand is pretty heavy in stock trim and I was hitting a water fall climb pretty hard. Made it up though.....
Romans 7-8
Old 06-16-2013, 07:17 PM   #53
2" 250 wall, dont make links over 40" for lowers or u askin to bend them
Old 06-16-2013, 09:10 PM   #54
Correct!! Green s10 I built bent a rear one and they right at 40" of tube... Swapping out for 2.5" by .5" wall now
Old 06-17-2013, 08:14 AM   #55
cmartin
cmartin's Avatar
Ground to frame where front/rear doors meet is 15" with 2" lift and 31" tires on my 1998 Grand. so roughly 13" bone stock.
Thanks that means I'm at 11" higher +- right now. May need to lower it some
Old 06-24-2013, 07:49 PM   #56
cmartin
cmartin's Avatar
Got the rear mocked in last night. Thanks to huntingmatt418 and joe. Everything looked good and ready to burn in. Until the test flex when the jack slide out from underneath the jeep and it slammed back down on the jack stands. Luckily no one was in its path. Seemed to flex good
Old 07-18-2013, 08:22 AM   #57
jlynch
You gonna build this thing or just sit and look at it? June was the finish date and we are headed into August
Old 07-31-2013, 05:46 PM   #58
huntingmatt418
Jeep
At some point, is there going to be building going on in your build thread?? Just asking.
huntingmatt418 is offline   Reply With Quote
Old 07-31-2013, 08:42 PM   #59
jlynch
The build has stopped. The project is for sale as is.
Old 08-01-2013, 09:08 AM   #60
cincygman
Wow
Romans 7-8
Old 08-01-2013, 06:16 PM   #61
cmartin
cmartin's Avatar
Hard to rush perfection and laziness.
Got the the rear finally finish welded and painted around the brackets. Gonna put the links back in hopefully for the last time and have it sitting on its own weight.
I acquired a 4x8 sheet of steel that I'm gonna use for plating the front of the frame. If I do it right should go pretty fast. At least before jay-bird sells it hahaha
Old 08-29-2013, 11:42 PM   #62
cmartin
cmartin's Avatar
Have got alot done here lately. The plate has made this easier. Got the pieces cut out and the passenger side bottom plate and outside plate bent and welded in. Just have to weld the bends up. Moving over to the driver side then going to do the inside plates. ( haven't cut them out yet )
ID:	7024   Click image for larger version
ID:	7025   Click image for larger version
ID:	7026   Click image for larger version
ID:	7027   Click image for larger version
Old 08-30-2013, 09:32 PM   #63
cmartin
cmartin's Avatar
Got all my parts for the front end and disc brake brackets for the 14 bolt
Old 09-18-2013, 08:46 AM   #64
cmartin
cmartin's Avatar
FINALLY THE FRAME IS DONE!!!!!!!!!!!!!!!
:beer: :) :beer:
Frame plating is done. The front end is set in and running the numbers on the 3 link thanks to huntingmatt. Man there's a lot to pack in a small area
Made some progress with the transfer case swap, the one I bought should work. Gonna be building links this week and hope to have them in soon. Then steering and fuel.
Old 09-18-2013, 08:40 PM   #65
walker
walker's Avatar
Chicken Fry?
walker is offline   Reply With Quote
Old 09-18-2013, 10:26 PM   #66
cmartin
cmartin's Avatar
Originally Posted by walker View Post
Chicken Fry?
That's the goal. I think it will be wheel able just don't know if it will have all the final touches by then
Old 09-19-2013, 05:51 AM   #67
kyrel69
Chicken Fry?
for those who do not know that is the first weekend in Nov.
Old 09-20-2013, 07:04 AM   #68
huntingmatt418
Chicken fry next year maybe
Old 09-20-2013, 01:54 PM   #69
cmartin
cmartin's Avatar
Your turd may be done and we both can go next year
Old 09-20-2013, 02:36 PM   #70
Cmartin this must b your one friend that is single and has a cake job and no responsibilities to anyone and eat sleeps And breathes in his garage and gives all his friends crap cause they can't do a ground up jimmy smith buggy build in 3 days... Lmfao
I got few o those friends lol
Old 09-20-2013, 05:29 PM   #71
cmartin
cmartin's Avatar
Hahahahahahahaha
Old 10-06-2013, 11:45 AM   #72
cmartin
cmartin's Avatar
Got a lot done here lately. The spring buckets on and gusseted. All the 3 link bars made and tacked in. Test flexed without the springs. Panhard bar has a finger width clearance under the oil pan at full bump. No binding issues I could see. Put springs back in and cut the driverside rear fender out. Hopefully have the tires on today and test flex with everything on. :beer:
ID:	7083   Click image for larger version
ID:	7084   Click image for larger version
ID:	7085   Click image for larger version
ID:	7086   Click image for larger version
Old 10-06-2013, 11:50 AM   #73
cmartin
cmartin's Avatar
A few more
ID:	7088   Click image for larger version
ID:	7089   Click image for larger version
Old 10-06-2013, 11:36 PM   #74
cmartin
cmartin's Avatar
Test flex went good. Took it up 20". That was all the farther I felt comfortable doing with a jack under the tire.
Still had plently of room to go with the springs. But need a lot of trimming on the rear outside fenders. And I took the door trim off. I like the clean look without them
ID:	7091   Click image for larger version
ID:	7092   Click image for larger version
ID:	7093   Click image for larger version
Old 10-06-2013, 11:47 PM   #75
Man that thing turned into a beast. Nice work!
And you're right about the trim. I dont think I've seen one stripped down before, it does look alot better...
