Old 10-07-2013, 08:29 AM   #76
Better put a notch in the oil pan! It is amazing how things that should not contact each other find a way to contact somehow. The rig is getting big!
Old 10-08-2013, 03:04 PM   #77
cmartin
cmartin's Avatar
Thanks guys. I'm really liking how it is coming together. I hope if the bar notches the oil pan it only goes up a little with no leaks. :)
Old 10-08-2013, 06:18 PM   #78
looking good!
Old 10-08-2013, 06:43 PM   #79
x2... I don't believe that finger distance will be enough for deflection of the whole assembly... good news is that it will "self clearance" fairly easily, the bad news is that the potential damage to an oil pickup could cause serious problems down the trail...
Just my opinion...
Looking great!
Old 10-08-2013, 08:09 PM   #80
Just my opinion...
Looking great!
X3... I thought I had enough room between my oil pan and my steering ram, but after bottoming the front end hard a few times it made a nice imprint in the pan. Luckily, no leaks.
Old 10-09-2013, 09:11 PM   #81
cmartin
cmartin's Avatar
We built the jeep at ride height. I cut the upper pan hard bracket to fit with the numbers. I guess missing the oil pan was a bonus on the first try. I'll keep an eye on it but will need to order another one to get it to mount in a lower hole. Thanks for the input
Old 10-13-2013, 10:02 AM   #82
jlynch
Reason why this isn't done yet.
Old 10-13-2013, 11:24 AM   #83
cmartin
cmartin's Avatar
Hahahahaha it was break time
Sent from my DROID BIONIC using Tapatalk now Free
Old 10-13-2013, 01:23 PM   #84
huntingmatt418
That explains a lot.....
huntingmatt418 is offline   Reply With Quote
Old 11-07-2013, 05:01 PM   #85
cmartin
cmartin's Avatar
After some prying and pulling was able to split the 249 and get out the input and planetary. The 231 was a lot easier to split. It already had a 6 gear planetary that I could use with my input shaft. Cleaned it up and put it back together. Hope to put it up in the jeep in the next few days
Thanks to huntingmatt418 joe and rolf
ID:	7194   Click image for larger version
Old 11-16-2013, 12:14 PM   #86
cmartin
cmartin's Avatar
Had to order the transfer case to trans studs. I couldn't get the ones out of my 249. So the new case to go in this week.
Got the disk brakes on the 14 bolt.
Old 12-01-2013, 09:59 AM   #87
cmartin
cmartin's Avatar
Cut the fenders last night. I like the back but rethinking the front. Got some inner fender area to cut out and rebox in the front behind the head lights. The battery box and air box will need moved. Thanks to the guys who came and hung out yesterday
ID:	7319   Click image for larger version
Old 12-07-2013, 03:56 PM   #88
cmartin
cmartin's Avatar
Ordered a custom fuel cell from RCI. It is the 30*12*9 but I had them not put in the sending unit or pick up lines on it. I bought a fuel cell adapter ring from genright that uses the stock jeep sender with the In tank pump and regulator.
ID:	7335   Click image for larger version
Old 12-09-2013, 12:00 AM   #89
cmartin
cmartin's Avatar
A few pics of the fender and door on the passenger side after the cut. I started the fill in process. After a lot of trimming and fitting I got the fill in piece to fit and filled. Not to bad since I hadn't ever worked sheet metal before.
ID:	7337   Click image for larger version
ID:	7338   Click image for larger version
Old 12-15-2013, 09:43 PM   #90
cmartin
cmartin's Avatar
Got the door sealed up and the inner fender finished at the bottom.
ID:	7343   Click image for larger version
ID:	7344   Click image for larger version
Old 12-15-2013, 10:10 PM   #91
cmartin
cmartin's Avatar
Also got my fuel cell I ordered from RCI. Looks good. Plenty of room for the genright adapter
Old 01-02-2014, 12:24 AM   #92
cmartin
cmartin's Avatar
Got the genright adapter ring installed tonight. I used a ΒΌ" drill bit for the holes and a jig saw with a metal blade for the big hole. I also put masking tape down to protect the cell.
The gasket maker I used. Seemed thin but got sticky quick
Put together
If anyone uses this adapter put the gasket in the adapter NOT on the sender. Ask me how I know. :mad:
All installed
Old 02-03-2014, 12:21 PM   #93
cmartin
cmartin's Avatar
Been trying to get back at it after the holidays and cold weather. Got the inner fender on passenger side almost done.
Rough fit
Also got all the fittings and steering column adapter. Hope to finish all of the steering up soon.
Old 02-06-2014, 08:00 PM   #94
cmartin
cmartin's Avatar
Got the fender well welded in
All boxed in
Cut the trim panel to fit. Don't know if I like where the pocket was since I had to cut it out. O well I want to have the trim in. At least from behind the seatbelt forward.
Old 02-19-2014, 12:06 PM   #95
cmartin
cmartin's Avatar
Got the jeep spun around in the garage this past weekend. Now I can start on the driver side rear fender.
Took a break on the fenders to work on the steering a little bit. Got the new pump.
Made templates for the orbital mount. Plan on using the steering gear mounting holes to bolt the mount to the frame
And cut the steering shaft so it will slip in and out. It was pressed at the stock length. Grinded off the pressed part and now it slips
Stock length 21"
Collapsed to 16"
Also had to file a little on the inner shaft cause it had some kind of a coating that made it to tight to slip easy.
Old 02-25-2014, 11:23 PM   #96
cmartin
cmartin's Avatar
Got the bracket for the orbital made up. It was harder than I thought it would be to fit it in there. It ended making the steering shaft a little closer to the header than I wanted but ended up good. If I would have angled it the orbital lines would have ran close to the belt.
The reason for the bracket. The unibody has an offset where the steering box was.
Test fit
All mounted up
Ran wire for the lengths of the hydro lines. Got them all mocked up.
May run this one in front of the upper bracket. But there is more room than it looks.
Old 02-26-2014, 10:10 AM   #97
jlynch
Looks good nerd.
Old 03-05-2014, 12:12 PM   #98
cmartin
cmartin's Avatar
Back on the fenders. Got the fuel door opening closed up. The opening had a rolled lip that made it easy to fit the filler piece in and weld. I completely welded the outside and put a lot of tacks on the inside on that lip.
The inside
Old 03-18-2014, 05:38 PM   #99
cmartin
cmartin's Avatar
Got the rear fenders done. The trim panel is trimmed.
How I think I'm going to set the tank. To keep room for the batteries. If they don't fit on the other side I'll center the tank.
Passenger side
When I get my battery boxes I'll see if they fit in the extra space. If not I'll back up and punt and try something else with them.
Old 03-21-2014, 09:02 AM   #100
huntingmatt418
It's no white jeep bud, but looking good!!! I can't help but admire my handy work hahaha.......
