05-31-2010, 09:12 PM | #1 |
3 Link Question...
I am having to 3 link the front of my Sammy-ish rig due to clearance issues. My question is, should the upper (frame) mount for the panhard be to the inside or outside of the frame?
Thanks! |
05-31-2010, 10:13 PM | #2 |
Put it outside, that way the panhard bar can be as long as possible and won't pull the axles to 1 side as bad when it drops out. Also if you have normal steering(not full hydro) keep the panhard bar parallel with the drag link.
06-01-2010, 04:12 PM | #4 | |
That little thing on the bottom of the engine called the "oil pan"... |
06-01-2010, 11:02 PM | #5 |
06-02-2010, 01:52 AM | #6 |
REverse the triangulation of the bars that aren't clearing the pan... there shouldn't be any reason it wont clear...
fark 3 links and panhards... they are the suck. might as well run a radius arm setup.
06-02-2010, 04:22 PM | #7 |
I will try and get a few pics up this evening...
