i have a sammy and i put yota axles under it with 456 gears i got 6.1 gears in the transfer case and 33/12.50 boggers on it now im havin a problem with when i take it out i brake my transfer case mounts on the frame and have threw my rear drive shaft twice and i get it fixed and it breaks again so i dunno if it my buddys work that keeps failing or what maybe im just geared way to low and thats what is causeing it i was just wanting some outside input to how to fix my problems with it thanks for your input
problems
With a stock samurai the t-case mounts are weak. I had 32's with 6.4 to 1 case and stock axles and gears and needed to rework the entire t-case cradle. Needs to be ridgid! They make bolt on kits to fix this and as long as you buy the good kits it will work. Mighty kong is the name of the kit I think. Look at how it is made and build it like I did.sigpic
truggy is right if its the stock mounts your breaking it is because they are way over stressed. many manufactures have t case buckets and the 3 mounts to choose from so my suggestion is get on izook and check out the links and get some parts or some good ideasOne of these days Zuk 2.0
Is this the sammy thats kinda back halved sitting at crack heads house? If so your pinion angle is too steep,so when the springs wrap up it binds the U-joint and breaks it.You'll need to cut the spring perches off the axle and rotate the pinion down. Are the steel arms of the T-case breaking,or just the rubber mounts between the arms and the frame?Last edited by Nuts; 09-10-2008, 06:59 PM.
Originally posted by tree_bashed_sammy View Postyea its the one. he never worked on it and then it started gettin messed with so i took it only thing he would say to do is move the rear end back and turn the case sideways somehow i dunno how he meant that. its breakin where the mounts bolt to the case
Originally posted by fabricator View Postany of you guys got a targa bar for a sami
that can be bought cheap?
