i have a 97 & 80 model jeep. both have 4in lift. 97 has a 4 cyl. and 33 no power. what gears would u prefor or would u change motor? only has 70,000 mileson it. the 80 so far i have redone the frame. it has 2 piece rear axles junk they keep breaking does anybody have a fix 4 it? it has a 304,33tires thanks 4 any feed back.
new to the club
If you've got the money and time, go with a motor swap in the 97. The 4.0L is a great motor, with plenty of power for 33s. If you can't afford a motor swap, 4.10 or 4.88 gears will help get it moving, but you're going to lose a lot of top end.
As for the 80, there are 1 piece axles available for it. The kits run less than $300. Should be a simple swap, although I have never done it. Ultimately, you should look for a stronger axle then the AMC 20 you've got in it. You can't polish a turd too much.
The Model 20 should handle a 304/33" tires just fine with a little work, How wild do you get when you wheel<
The factory 2 piece axles are absolute ****.... after that the housing is the next weal link. If you have a good straight housing with intact plug welds then I wouldn't be afraid to but a 1 piece kit in it and go.
The R&P of a 20 is stronger than a D44 , seen lots of busted pinion gears on rear Dana 44's.
I broke both M20 and D44 rears and ended up with a 9" that lasted...
Originally posted by pipedope View Posti have a 97 & 80 model jeep. both have 4in lift. 97 has a 4 cyl. and 33 no power. what gears would u prefor or would u change motor? only has 70,000 mileson it. the 80 so far i have redone the frame. it has 2 piece rear axles junk they keep breaking does anybody have a fix 4 it? it has a 304,33tires thanks 4 any feed back.
on the TJ put at least 4.88's or 5.13's if you are go up to 35" tires. keep the motor with that many miles engine swaps can be expensive cause you will need to change the trans and t-case or t-case in put. harness and computer.
I have a whole 4.0 motor/trans swap/t-case/harness/computer available low miles If you have the $$$ to play with
I also have some good M20 one piece axle sets for your axle if intersted? Moser and Superior
i do my own fab work. family welding shop--fab shop. if u goto woodsbuggy.com type in pipedope you will see my own design of my rail buggy.its also on drews off road web site home page.i have a 1 year old boy so i bought the cj to cruise in some mud with him.i climb in my buggy.i have around 20,000 in my buggy. also how much do u want for the 1 piece axles?
The four cylinders with stock gears and 33's are a complete dog. Granted the 4.0L six is much stronger but I've seen a lot of people pretty happy with the four banger with the proper gears. I *think* 4.88 is as low as you can go with the D35 rear/D30 front axles but not 100% sure. I know at least a couple people in our club that went to 4.88's with 33-34" tires and they said it was a huge improvement on the road. You shouldn't lose any top end at all going to 4.88's with the 4 banger with the larger tires, mainly because you will actually be able to use 5th gear again (the guy with 34" LTB's couldn't even pull 5th gear with stock axle gears unless going downhill). Though before spending the $$ on gears for the rear axle I would at least consider the options of upgrading, pending on what you do with the Jeep.
I agree that adding 1 piece axles to a AMC 20 makes them decent strength-wise, IF you do something about the housing bending. Another guy in our club got maybe a couple of years of easy to moderate trails out of the rear axle in his CJ-7 (stock 258 and 33" tires) before it got the smiley face look.
Pulling a buddies Rear Model 20 tonight. Fully rebuilt a few years back and not many miles since. Axle has 3.55 gears, 1 piece axles, and a lockrite locker. He is looking to sell if interested.
Also will have the 30 front fully rebuilt at the same time, also has a lockrite. He will also have some nice aluminum mickey thompson rims 15x10 with 33 boggers to go with the axles. Great setup, he just ran into some awesome deals on bigger stuff.
Everything is in excellent condition(he is very particular about his stuff). PM me if interested and I will get you his info1994 YJ, 4.0, 5 speed.
4.88 is as low a gear you can get for the lp30, i would do that ,and toss the rear in teh trash and get an 8.8 with discs for it with matching gears (8.8's can be had fairly cheap, and arent that hard to swap in if you can weld). i would do the rear axle swap at the same time you regear, or find a stock 44 to swap back there. as of the cj, i would put 1 piece axles in it for sure. and just so you know, a stock 304 isn't putting out a whole lot more hp than that little 4 cyl is.zuk buggy.....it'll be a jeep eventually.
