I Currently have a Dana 300 out of the CJ5. I was looking at building up a TH350 and matting the Dana 300 to it. I have the chance to get, for free, a TH350 w/ NP203 Tcase. the tranny doesnt have Reverse and needs rebuilt but the NP203 Tcase works. should i a.) Keep the dana and buy the adapter for the TH350/Dana. b.) Keep the NP203 Tcase hopefully its a passangerside drop. c.) ive seen some people double up the NP203/Dana tcases. is that a good option too? i need some help on this folks, and you guys seem to know whats going on!! Thanks in advance!
Dana 300 vs NP203
unless you are going to do a lot of stretchin 350 203 won't work. I run a th400 with 203/205 doubler and only have about a 20 inch rear drive shaft in a 110 inch wheel base cj7 But if possible I wouldnt use a 203 without a doubler check on the 300 adapter and figure out what trans and transfer will measure out Good LUckCasey built cj7, amc 360 fuel injected, 39.5 Irocs,14 bolt+60 detroits, 4 linked front and rear, 203/205 doubler etc...........
If it's a factory TH350/203 combo than it will be passenger side drop. The 203 only has a 2:1 low range and is a full-time case from the factory so no 2wd mode unless it's been converted (which was pretty common).
Personally I would prefer to go the 300 route.
Many people use the 203 range box that contains the 2:1 planetary for a doubler. A guy in our club has a TH350/203 range box/300 in his Samurai. It is stretched in the back but not an abnormal amount to fit, but it is supre tight. Based on that you could get it to work, but it's a lot more work and money for something that I'm not really sure you need.
just remember that the 203 is a chain driven pig. i always make a point to stay away from chain driven cases when it comes to offroad use. one broken tooth can/will ruin a good day in the woods !95 yj, fresh fuel injected 302, c-6, twin sticked 205, 3 linked high pinion d60 front, double trianulated 4 linked 14 bolt rear (all aluminum links) locked both ends, 4:56 gears, full hydro steering, high steer, 4 wheel discs, 16" 2.5 fox air shocks, 39.5" irok's. just finishing a full frame-up redo thanks to a great friend and one knowledgable(sp?) s.o.b casey cravens for without him this could not have been done in such a short time and done right!
Originally posted by boomhauer View Postjust remember that the 203 is a chain driven pig. i always make a point to stay away from chain driven cases when it comes to offroad use. one broken tooth can/will ruin a good day in the woods !
Better late than never....
203 vs. 300... ...BOTH!
Below is my NP435 trans with an NP203 (low range gearbox) in a Chevy variety, flipped upside down, with a 23 spl Dodge input gear in it... with Dana 300 bringing up the rear...
(T-150 looks sooooo small next to this)
By the way, if I had to do it over, I'd have bought a STaK... but the doubler should provide me with hours of shifting entertainment...brad
sigpic
By the way, if I had to do it over, I'd have bought a STaK... but the doubler should provide me with hours of shifting entertainment...sigpicchris hodges
Originally posted by gothodgie View Postvery nice setup... what is the 1st gear ratio on the np435 ?
And yes, I specifically went with 203 / 300 because the gears were different ratios (as opposed to the 203 / 205 which would certainly be stronger, but they have numerically identical gearing which limits gearing options)
203 = 1.98:1
300 = 2.62:1
I also did 32 spl outputs front and rear of the 300 just as Truggy said...
All told, I have less in my setup than a STaK, but far more to go wrong...
3-spd STaK is far better than "nice."
ps - I run 4.10 gears in difs... I like 4.10 gears... I choose to get increased torque through tcase(s)...Last edited by KargoMaster; 11-09-2009, 11:19 AM.brad
sigpic
Last post just to clarify my setup...
To make all this possible, I needed to replace the mainshaft of the 435...
Top is new main shaft (23spl output, only about 2" stickout)
Middle is stock 2wd main shaft
Bottom is the 4wd main shaft (stock adapter/housing is like 9" long )
sigpic
