Cheapest, best hiems?
  • Cheapest, best hiems?
    Where is the best place to get hiems joints?
    LIKE IT OR LEAVE IT!!!
    Cheap and best NEVER go in the same sentance!
    But check these out..
    http://www.ballisticfabrication.com/...ints_c_12.html
      cheapest place you are going to find good quality cheap chromo heims is
      www.midwestcontrol.com
        polyperformance for ones that will hold up under severe conditions. They have great tech help.
        sigpic
          also, www.branikmotorsports.com stan is awesome to deal with, i believe they were $32 for the good qa1's last time i got some from him. you can buy the lower quality qa1's (that i've never had a problem with, run them on many rigs, including butch's old rockwelled cj) for about $14 a piece from www.ubmachine.com
          greg
            Straight from QA1 by pass the middle man.
            • #7
              94dodgeTruggy is a TSC fan cheap noisey but never broke one.
              • #8
                Ran those on truggy and was amazed but boy they sure were noisy!
                sigpic
                • #9
                  Yeah you could hear that thing coming from the other side of haspin. But that poor thing got beat.
                  • #10
                    noisy heims
                    Dry grafite spray works great for lubing your heims,and i'd say it helps with the life of the joint also.If you can't find the grafite spray....WD40 is better than nothing.A little maintence goes a long way.You don't want to use grease as it collects and holds dirt although some heims are made with grease fittings.Just my 2 cents worth!:)
                    • #11
                      No kidding. The YJ sounds like my grandpa going down the trail.
                      • #12
                        If you check out Ebay, Barnes 4x4 has a complete set up with 8 heims, jamb nuts and inserts for about $225. Those are Midwest Control. I think it's a pretty good deal for the package.
                        • #13
                          steve you now need a new screen name!!! lol
                          • #14
                            try www.ruffstuffspecialties.com they come in pairs with tube adapters and high misalignment bushings pretty cheap 3/4x3/4 $39.00pair
                            Later Jeff
                            • #15
                              That is why they have grease fittings so clean grease can force the dirty grease out after a run.
