If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
OK this Welder is awsome. The infinate adjustability beats the crap out of the Lincoln and Millers (ones in the same price range) with the 7 tap transformers.
Avortec is in Michigan, the owner builds this equipment and started just in Industrial applications but is now getting into the small "shop" size stuff under 480v3ph.
It's set-up with a 125 size mix gas bottle and an 11lb. spool of mig wire. I've done some thin filling screwholes in bodywork stuff, as well as some 1/8" and 1/4" frame brackets.
