Yota axles questions
  • Yota axles questions
    Ok, I have maxed out my sami axles and I keep braking stuff...
    specs:
    5.38 gears
    lockers front and rear
    chromoly birfs
    calmini hd rear axles
    disco brakes in rear
    4.1 tcase gears
    on 9.50x16 ag tires.
    now looking around it seems that the 85 yota axles 4.10 are the ones to find and get for a new swap out.
    what is the most bang for my buck to upgrade on the yota axles to get something close to what i was running with the sami axles?
    5.29 gears?
    chromoly axles and birfs?
    weld rear and detroit locker front? pro/cons ?
    trail gear lockout coversion?
    6 shooters?
    oh yeah still running tracker p/s with mod pump and cooler.
    Any issues that some one can see that I will need to swap some thing out for the steering (full hydro but not in the budget yet...), braking,etc...
    wonder if you were thinking of selling the sami axles :confused:;)
    2013 RZR S
      Im by no means a yota guru, but I had built toy axles in my rear engine moon buggy, and had a lockrite in front that caused me headaches, so I would steer clear and stick with the detroight idea..
        Yea lockrites are junk. I got a yukon grisly and it works great. And for axels, longfields are the the best. I run 39.5 tires and Ibeat the hell out of it and NEVER broke a axel or had any problems out of locker.
          Sorry to hear you guys have had bad luck with lockrites... I agree the suck in the front, but i have run them in the rear of every Landcruiser i have ever had... The longfeilds are about the only thing i would put up front for an axle upgade, the warranty is the best you will find...
          If you want to find more info on the Yota stuff look on IH8Dmud.com ... Here is a link to the Yota mini truck section http://forum.ih8mud.com/79-95-toyota-truck-tech/...
          sigpic
            Longfields are the only axle to run. I run 38 sx's and never had any problems. I'm not easy on them either.
            Willys buggy 4.3, 350 trans, toy axles, linked suspension, air shocks
            • #7
              I read a while back that Bobby Long had a bad batch of axles in 07 or 08, and those are the only ones i have ever heard of anyone breaking... He's such a great customer service guy that he tried to contact anyone that had gotten a set of the axles out of this batch so he could warranty them before anyone had problems.
              That sold them for me... Now i just have to save the $ to get some...
              sigpic
              • #8
                I had a lock rite in the front of mine for years,had a hard time getting it ratchet. I did finally replace with air locker best choice I made.
                The front 4.10 gears with your t-case will do you good.The start of upgrades you can do is dirty thirtys from trail gear, and up grade as you can afford.
                If you leave front end unlocked stocks hold up pretty good,but once you lock they don't hold up as well.
                I run all upgraded front end parts and spool in rear.
                Hope this will help.
                FYI had lock rite for 6 years.
                • #9
                  Yeah he sold the bad batch to trail gear and theve been selling weaker knock offs ever since
                  • #10
                    lol....
                    sigpic
                    • #11
                      i have had both dirty 30s and longfields. longfields are the way to go.lockrites are ok i ran one in my front for 3 years. but detroit is the way to go if your running 36 or bigger tires.
                      • #12
                        I'm runnin 37's
                        • #13
                          5.29 gears?....I would.
                          chromoly axles and birfs? Longfields.
                          weld rear and detroit locker front? i wouldn't put a lockrite in it
                          6 shooters? Too much money.... c link
                          http://www.pirate4x4.com/forum/showt...highlight=stud
                          u would need to run histeer and maybe a toyota p/s pump
                          • #14
                            I have a set that with a little work, would get under that sami quickly...
                            4.62 gears, locked front spool? welded rear, rear disco setup with anti wrap (tractor supply) bar.
                            need one chromoly and hub ( locker bolts sheared off) maybe brake pads or calipers on front not sure I took this apart when i need parts for splattt..
                            • #15
                              also are the stock yota's
                              27 spline or 30 spline, I did see the
                              longfields- 645.00 vs the dirty 30 - 579.00
                              they both seem to be made from same material not much a price difference..
                              so most say go with the longfields!!
                              are the creaper flanges a good upgrade? pros/cons?
                              http://www.trail-gear.com/hubs-and-drive-flanges
                              they seem like they would be..
