Hey guys and gals...well the plumbing is gettting worse...anybody have Brody's phone number? might have todig up the front yard....ugh
plumbing issues
When you snaked it out, did you use the 3" cutter bit? As long as the pipe isn't crushed, snaking it and a regular dose of root killer should keep it clear. Always make sure only toilet paper goes down. Paper towels or anything else will give you problems. Replacing your pipe will be expensive. It was $3000 to have a section fixed in one of the apt buildings where I work.
Originally posted by 93 Krawler View PostWhen you snaked it out, did you use the 3" cutter bit? As long as the pipe isn't crushed, snaking it and a regular dose of root killer should keep it clear. Always make sure only toilet paper goes down. Paper towels or anything else will give you problems. Replacing your pipe will be expensive. It was $3000 to have a section fixed in one of the apt buildings where I work.--------
O____O
(O|||||||O)
--O---O--
Originally posted by began View Postnobody can ever get a 3" cutter through...only the small ones our pipes are a pain to get through. im hoping its just roots again but who knows...what root killer do you suggest?
Plumbing supply places probably have the best stuff. I just get it from Lowes.
Originally posted by 93 Krawler View PostYou going through the main cleanout in the floor?
Plumbing supply places probably have the best stuff. I just get it from Lowes.--------
O____O
(O|||||||O)
--O---O--
Originally posted by began View Postevery time we have people come in they get caught up in the vents...they need to go through the basemtn toilet...only way to hit the main line out.
