I will eventually be looking for a trailer. I would like something in the 25-30 foot range so I can tow a friend also. What should I expect to pay for something like this?
Gooseneck flatbed trailer
sigpicchris hodges
3 to 5 grand (used)depending on condition. I have a 24 ft goose neck. just barely long enough to tow two. I have put a jeep on the front and a full sized rig on the back.
My father in law is thinking of selling his 30 ft goose neck. Interested?1976 CJ 5
1984 CJ 7
1993 K3500 GMC 6.5 TD
Originally posted by tbshakie View Post3 to 5 grand (used)depending on condition. I have a 24 ft goose neck. just barely long enough to tow two. I have put a jeep on the front and a full sized rig on the back.
My father in law is thinking of selling his 30 ft goose neck. Interested?91 fj 80 on 37 Nitto Muds with a 10k winch. Cage and sliders coming soon.
My 24 ft deck over goose neck weighs 4,940 lbs. Has 2-7,000 axles, and can hold 12,000 lbs. So fully loaded the whole combo can weigh just under 17,000 lbs.
The 30 ft deck-over goose neck weights 5,600 lbs. Its is set up for 3 axles, but currently has 2. With three axles, it should be good for 19K pounds on the trailer.
I borrow an F450 when I tow this much weight.1976 CJ 5
1984 CJ 7
Originally posted by tbshakie View PostMy 24 ft deck over goose neck weighs 4,940 lbs. Has 2-7,000 axles, and can hold 12,000 lbs. So fully loaded the whole combo can weigh just under 17,000 lbs...
Learn something every day.DIRTY DEEDS, DONE DIRT CHEAP
pretty sure you need CDL over 10K trailer these days I guess it depends on your tow veh GVW
"Any combination of vehicles with a combined gross vehicle weight rating of 26,001 pounds or more, provided the gross vehicle weight rating of the vehicle or vehicles being towed is in excess of 10,000 pounds;"Last edited by timido; 08-23-2014, 05:41 PM.
You don't need a CDL for your own personal property regardless of the weight or combination. Once you start making money (your own buisness) or hauling for a company then you must acquire a CDL. You can buy a full tractor trailer and load up to 80,000 pounds and drive it around all day as a daily driver if you choose too.No need for a Winch...You just have to make it !!
Originally posted by WrenchMonkey View PostSo the other 3k is tongue weight? I never realized they put that much load onto the tow rig...
It was an idea. Not something that will definitely happen. I do know the previous owner pulled 15-20k regularly. My 80 weighs around 6k empty. When I'm ready I may just go with a 20 foot and be done with itLast edited by itbrokeagain; 08-25-2014, 11:38 PM.91 fj 80 on 37 Nitto Muds with a 10k winch. Cage and sliders coming soon.
Originally posted by jeepmanjeff View PostI have a F550 4x4 RV and a 30' deck over tongue trailer. CGCW with 2 built jeeps is roughly 31k lbs.
I will sell it all! come lets make a deal! :) :) :)
(Really nice setup, man...)DIRTY DEEDS, DONE DIRT CHEAP
25 is absolute Minimum to tow two rigs. We put two on a 25' and it is very tight, as in bumper to bumper tight on it. 28' is much better, as we commonly tow Two rigs in an enclosed 28' trailer and they fit much better in there. One day i want a 30' deck over though. Check weights on trailers as said before, two 7k axles won't get you real far so i suggest either a tri-axle or dual tandems for a 20k+ trailer rating.
when i was looking, one could be had for 6k new for a bare bones trailer, used from 3k up depending on condition.beat up rusted out k5
only problem with dual tandems (9,000 lb axles) is that the trailers are usually that much heavier (weight wise). instead of a 5,000 lb trailer, its now 7,000 lbs. and you need a bigger truck. you will be fine with 2-7,000 lb axles pulling 2 jeeps. go duals for 2-fullsized rigs. 24 ft in bare minimum for 2 jeeps (I have to take the spare tire off the first one, bumper about 2 inches away from each other, about 1 ft of trailer length left.) its tight, but it works.1976 CJ 5
1984 CJ 7
Originally posted by underpowered View Posttwo light rigs can get away with on two 7k axles, but when dealing with much other than jeeps or yota's you need either the duals or a third axle. You can quickly overload a 14k trailer when you think of how much the trailer itself weighs.sigpicchris hodges
