new guy from ky with a 4runner
  • new guy from ky with a 4runner
    Hello figured I would join here and try to do some wheeling. I live in northern kentucky but work in Cincinnati. Here's some info about my truck.
    1985 toyota 4runner powered by a Mercedes 5 cylinder turbo diesel. Chevy leaf springs on blocks. Factory toyota 5 speed with solid axles. Its a beast. Gets about 25mpg. Need to fix a few things and hopefully I can use it to tow my beetle around.
    - 4" suspension lift
    - 63' Chevy Springs in the back/ HD Rough Country springs up front
    - 35" BFG All-Terrain Brand New. (Still has the tabs from the injection mold.)
    - Solid Axle. (was cut and turned to correct drive angle. (Moved forward 3" for better approach))
    - High Steer
    - Square Tube front D/S (0 Vibration) Need new Teflon bushings to quiet the chatter at low speeds
    - Gusseted for support
    - Steering dampener
    - Tom Woods Custom Rear D/S
    - Stainless Braided Brake Lines
    - Custom Fabricated Oil Filter Relocation Adapters to allow easy filter access
    - Rebuilt Turbo
    - OM617.952 Motor
    - New Head Gasket (installed while the motor was being fitted)
    - New Monark Injectors. Pop tested @ 2000psi
    - Modified Alda
    - Modified Injector Pump (Rack Limiter Removed)
    - Hybrid 8 Puck Clutch/New Pressure Plate
    - Front Mount Oil Cooler
    - Dual Manual Controlled Cooling Fans
    - 4000psi rated ¾ and ½ hydraulic lines for oil delivery
    - 2.5 Turbo Back Exhaust
    - New Timing Chain
    - New Fuel Lines
    - Transmission is a stock W56 capable of withstanding the Torque of the Straight 5 Diesel
    - Top Shift Transfer case
    - Stock SR5 Altimeter/Inclinometer
    - Aftermarket VDO Boost/EGT gauges with 4Runner Specific 2 Gauge Pillar
    - All stock gauges function except for the RPM Gauge
    - Leather Specialty Toppers Soft Top (included)
    - Hard Top w/ Integrated internal LED lighting (Very Bright)
    - Rear Mounted Battery (backup)
    Come out and join us this Saturday at Haspin Acres or Sunday at DTOR.
      I wish I could go this weekend but I have other things going on. I only live 40 mins from dtor
