heard good things and bad. really all i need to know is it a better 30 than the stock one in my tj. bolts directly in and everything. heard that the hp 30 and a super 30 kit makes it almost indistructable.
hp 30
Originally posted by mossyoaktj View Postheard good things and bad. really all i need to know is it a better 30 than the stock one in my tj. bolts directly in and everything. heard that the hp 30 and a super 30 kit makes it almost indistructable.
Well, A HP D30 is stronger and a Super 30 kit can make it 30 spline if you change carrier/locker. stock is 27 spline.
Your in luck I have a HP D30 housing sitting here for you!
how much for the housing adn what all is included. and what size tire would this thing finished be able to handle locked and 30 splinedOriginally posted by JET455 View PostWell, A HP D30 is stronger and a Super 30 kit can make it 30 spline if you change carrier/locker. stock is 27 spline.
UNITED STATES MARINE
sigpic
A 30 indestructable? Never possible. Ring and pinion are small and the ball joints and knuckles break and the axle tubes are thin. You can put alot of money into them and make them survive with moderate wheeling and 35's. Most use the 30 fronts due to not wanting or being able to do a swap. Keep it open with spider gears or air locker and cross your fingers if you wheel difficult terrain often!sigpic
I tend to agree.Originally posted by 94Dodge Truggy View PostA 30 indestructable? Never possible. Ring and pinion are small and the ball joints and knuckles break and the axle tubes are thin. You can put alot of money into them and make them survive with moderate wheeling and 35's. Most use the 30 fronts due to not wanting or being able to do a swap. Keep it open with spider gears or air locker and cross your fingers if you wheel difficult terrain often!
Also, don't forget about the unit bearings (wheel bearings). I doubt they would last very long with the big tires.
Of course, a HP30 with the bling Super 30 kit probably would be considered indestructable in certain conditions........like if you still ran a D35 rear axle because you would always grenade it first.
