Onboard air system
  • #16
    Originally posted by 94Dodge Truggy View Post
    5 lb or 20 oz. tank large enough?
    Nah, 10lb is the minimum. If the CO2 tank could be used horizontally, I'd have a 20lb, but if its mounted on its side, frozen CO2 can squirt into your tire---not good. 5lb too small.
    Unimog 406
    • #17
      Cant beat the "MV-50" superflow sold at Pep Boys for $60.
      Here's a write up on how to port the head and make it work even better. After the mod, it will fill a single 33" tire from 18psi to 35psi in just over two minutes.
      http://www.4x4wire.com/index.php?opt...ects&Itemid=83
      I've got 2 that I plan on running together with a 5 gallon tank.
      88 4Runner, 350 V8 swap in progress
      http://staff.4x4wire.com/adamf
      • #18
        I have an extra York 210 compressor, would make a nice OBA with a bit of fabrication..
        It's a V-belt with working elec. clutch..I'll let it go cheap!
        • #19
          Thanks for the offer. I have 2 extra compressors already. The engine bay already has one for a/c and is getting tight for space with the coilovers in the way and other junk. I am leaning towards CO2 from ultimate air now.
          sigpic
          • #20
            I've got a beverage tank from Sparkling Carbonic as Wilson1010 mentioned. Works well and the price was right. I might have about $130-$140 dollars in the whole setup.
            '99 TJ
            Terrain Stompers Jeep Club
