Originally posted by boomhauer
View Post
Dana 60 Shaft Upgrade
Originally posted by mckeddie View Posthave you ever seen em break an inner shaft though? hopefully i'll get to see em pop a couple at harlan then.
I have Yukon 35 spline inners & outers, w/ Longfield Super Joints, and 35 spline drive flanges. I do not want any weak links in my setup because I have a Detroit Locker. If and axle/joint/flange/lockout, etc were to fail under load, I have an excellent chance of wiping out the $550 locker. If you run an ARB, spool, welded front diff, (or even a Lockright), etc, this is less of a concern.
Back to the shafts: I have a slight but visible twisting of the splines on the short side inner. It has been that way for well over a year. With that said, I've wheeled the truck less this year than I have in the past five years.
RoyLarge: 1978 Ford F-250
469 V-8 on Propane
C6, NP-205, 4.10's, 42" TSL's on 15x8's
D60: Detroit, 35 spline Alloy Shafts w/ Longfield Superjoints,
Dedenbear Knuckles, Drive Flanges.
1410 Driveshafts, D70-U Welded, 12K Winch,
A-6 OBA, Rapid Weight Loss, Personality
www.ohio4x4.com
Medium: 2009 Yamaha Grizzly 700
Fuel Injection, Power Steering, Diff-Lock, 27" Tires, 5K Winch
Small: 1993 Suzuki DR350 S
I have not broke the front 60 yet and thought that I would have by now. I have 2 extra warn 30 spline lockouts for the stock shafts and another stock outer and just bought a 1978 ford complete with 400, c6, and 60's front and rear. Not so sure about upgrading now. Looking to order a mini stak 3 speed t-case for the winter project.sigpic
