On a CJ the spring hanger is bolted to the under side of the frame and not inside it like a YJ. It is pretty easy to just cut the YJ spring mount out of the frame and then plate the frame solid. Then drill two holes and mount CJ style spring hangers. You can also just pedrill the holes and weld nuts to the inside of the plating like Jeep did on the CJ's when they were new. It also gives about a 1 1/2" to 2" lift to the back. A little longer shackle in the front will match every thing back up.
FRAME REPAIR?? pics
Originally posted by KargoMaster View PostI guess Tony and I were just lucky...
Where was your aftermarket frame from GPER?
For me, it won't matter soon, that whole rear section is getting the axe (grinder).
Originally posted by maddhatter View PostOn a CJ the spring hanger is bolted to the under side of the frame and not inside it like a YJ. It is pretty easy to just cut the YJ spring mount out of the frame and then plate the frame solid. Then drill two holes and mount CJ style spring hangers. You can also just pedrill the holes and weld nuts to the inside of the plating like Jeep did on the CJ's when they were new. It also gives about a 1 1/2" to 2" lift to the back. A little longer shackle in the front will match every thing back up.
